    Jan 2006
    TRACY CALIFORNIA
    5
    Need Help Sizing New Unit For Walk In
    Hi everyone,
    I was wondering what HP condensing unit I should order for a walk in that we would like to keep at 35 degrees farenheit. The box demensions are 18ft 6in X 18ft 6in. This box at one time was a freezer with 2 condensers & 2 evaps, one compressor died and they left the other one running and used it as a cooler. I am in Walnut Creek california and it gets up to 115 degrees in the summer. Thanks in advance for your input. refermadness
    Jul 2006
    k s a
    55
    7
    Re: Need Help Sizing New Unit For Walk In
    Quote Originally Posted by refermadness
    Hi everyone,
    provid full dimensions L*w*h
    and what about ambient temperature there
    Dec 2004
    82
    14
    Hello :
    The load of the product you are putting in the walk-in cooler will determine the size of the condensing unit.
    Feb 2006
    derbyshire
    610
    sounds like you could adapt most of what you have providing its in servicable condition, just of the top of my head i would think a gas change to possibly R134A and expansion valves,driers etc assuming the existing unit is multi gas,poss oil change,one new unit to match the cooler[ask your wholesaler] do away with the electric defrost and put them on off cycle, i would rewire it also dissconecting things like door heaters,prv, etc. should make a good chiller with the extra insulation etc.
    Oct 2003
    5,630
    34
    If you could rewrite or edit our post in SI units, then I can possible give some recommendations.
    May 2006
    India
    82
    1,013
    If you can provide what temperature and Humidity you propose to maintain now inside the Walk In unit, the Products that is proposed to be kept, the product incoming temperature, the Walk In Wall, ceiling and floor insulation materials and thickness, then I might be able to suggest you the suitable capacity of the refrigeration plant.
  1. Daikin a/c units.
    By rick in forum Air Conditioning
    Last Post: 18-02-2008, 09:22 PM
  2. Problem with ducted Daikin
    By jutty in forum Trouble Shooting
    Last Post: 23-07-2007, 05:34 AM
  3. M I T S U S H I T A ac unit with no condensing unit
    By Chinua in forum Air Conditioning
    Last Post: 28-07-2006, 06:54 PM
  4. Sizing for Australia
    By dogma in forum Fundamentals
    Last Post: 17-03-2006, 10:05 AM
