Results 1 to 11 of 11
    Dec 2005
    28
    Mitsubishi Heavy Industries HELP
    First split I've ever put in, but i'm a bit confused, The felx cable fromt he indoor unit, I take it this is a the power cord and it needs a 3 core + earth to link the two together ???? Not to clear in the instructions
    11,025
    Re: Mitsubishi Heavy Industries HELP
    WHOA!, STOP!
    Just read the installation instructions carefully.
    Normally, but not absolute, power to outdoor unit, link power from outdoor to indoor unit; separate cable with control connection between indoor and outdoor unit.
    If you can give details of the model then we might be able to provide more detailed information.
    Dec 2005
    28
    its a srk 28,
    Dec 2005
    28
    It has a flex hard wired in and there is a 4 point terminal block on both the indoor and outdoor units
    Jun 2006
    Ireland(ROI)
    44
    28
    A lot of the newer smaller splits have the mains into the indoor and then to the outdoor.
    If there is a flex coming out of the indoor unit, this would lead me to believe that this is the case here.
    Sep 2005
    South West
    129
    Quote Originally Posted by Bakerbj
    Three core goes to spur/plug (yes i know it shouldn't really go to a plug but i am sure it will!)
    Connect 4 core cable which you will supply your self from the indoor unit to the outdoor compressor. They are number 1,2,3,4 in both units.
    Hope this helps.
    May 2006
    Nottingham
    72
    163
    Which SRK28 is it ZD (Inverter)?
    Are you saying...
    Mains feed into the Inside Unit from power supply,
    Then Live, Neutral, Control and earth to the Outside unit?
    Thats opposite to the Daikin method?
    So surely both cables would need to be at least 2.5mm. Low power unit fed first? Full load runs via the inside unit?
    Still needs local emergency isolation close to the outside unit (20a Disconnector switch) Breaking only Live an Neutral? (Not earth & control wire) of the linking cable.
    Dec 2005
    28
    thanks for that, didn't want to make a tit of my self o nthe first job. Also in the instructions is says to lag both the liquid and gas pipes in the same insulation ? shouldnt they be seperatly lagged ?
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by mick2me
    Are you saying...
    On some small wall units, Fujitsu, Mitsubishi, Hitachi & Daikool among others, all come with a power cord attached to the indoor unit for connection into a local supply. The interconnecting cable then supplies power/reversing valve/cond fan to the outdoor. As they run at low amps, (4/5A) 1.5mm cable is normally sufficient as this is rated for 19A.
    Local isolation at the outdoor is necessary to comply with BS7671.
    May 2006
    Nottingham
    72
    163
    Quote Originally Posted by frank
    Thanks Frank
    If I ever get this Daikin installed, A Mitsubishi SRK**ZD may be my purchase, for upstairs.
    Dec 2005
    28
    Installed it and work a treat, the cable is the power cable. H*P said you can just stick a 13a plug on the end, but i wired into a fused spur
  1. Mitsubishi problem
    By marc5180 in forum Trouble Shooting
    Last Post: 17-01-2007, 10:06 PM
  2. Mitsubishi heavy industrial A/C.
    By Langer in forum Air Conditioning
    Last Post: 14-08-2006, 11:31 AM
  3. MITSUBISHI Heavy Industries
    By coolit24 in forum Air Conditioning
    Last Post: 06-03-2006, 08:46 AM
  4. Mitsu Heavy Industry
    By bobjob in forum Air Conditioning
    Last Post: 14-07-2005, 11:00 PM
  5. Mitsubishi Heavy Industry
    By Abe in forum Air Conditioning
    Last Post: 09-03-2005, 08:37 AM
