Thread: Leaking!
24-07-2006, 05:17 PM #1
Leaking!
Have a portable unit, when i went to empty the water tank today, quite a lot of water leaked onto my carpet as I was moving it! Not from the pipe either, but from the bottom of the case. Is this serious? It seems to run normally!
24-07-2006, 06:46 PM #2
Re: Leaking!
just condensate ie water from the coil would be my first thought
24-07-2006, 06:58 PM #3
Re: Leaking!
Mop the floor and it will be fine.
24-07-2006, 10:18 PM #4
Re: Leaking!
Use the drain tube BEFORE you move it. They only have a shallow drain pan inside and the slightest movement will get the water sloshing about - hence your wet carpet.
If using the drain tube is a problem where it is sited then try and get some similar sized tubing so that you can extend the drain pipe to somewhere safer.Brian - Newton Abbot, Devon, UK
Coolmaster CU200, leaking
By Tycho in forum DomesticReplies: 18Last Post: 14-11-2006, 10:00 PM -
Leaking frost free fridge-freezer
By diment01 in forum DomesticReplies: 5Last Post: 22-06-2006, 11:49 PM -
leaking fridge evaporator
By rosliin in forum DomesticReplies: 3Last Post: 15-06-2006, 03:24 PM -
Leaking X430LS shaft seals
By reefermadness in forum TransportReplies: 14Last Post: 02-04-2006, 08:00 PM -
oil plate leaking?
By cpt. cascade in forum Trouble ShootingReplies: 4Last Post: 17-05-2003, 02:31 AM
