    May 2006
    uk
    Unhappy mitsubishi mr slim master and slave
    hi, the accounts department at works air con has stopped working, it is a mitsubishi mr slim master and slave system. i installed them in 2000 but they use a outside contractor to maintain them, the fault was the indoor air temperature probe has failed
    both air con units were oversized to cope with a office extention that never took place, so im happy that one unit can cope for the short term
    now unless im wrong, to get one of the units to run again, all i would need to do disconnect the master and slave wire link, change the dip switch settings
    is this right??????
    the contractor has quoted 2 weeks delivery time on the new probe and an office with 16 people in it are not happy!!!!!
    Nov 2004
    Nottingham
    37
    Re: mitsubishi mr slim master and slave
    believe you may be correct mitsi tech are very good 0870 3000 300
    May 2006
    uk
    Thumbs up Re: mitsubishi mr slim master and slave
    great thanks, i put the units on test just to get by for the time being
    thanks again
    steve
  1. slave under performing
    By stella in forum Technical Discussions
    Last Post: 27-05-2006, 05:08 PM
