Thread: Moisture in Propane Liquid
24-07-2006, 08:40 AM #1
Greetings to all
We normally recieve propane in trucks but it does have some moisture.
How can I find:
1. The saturation temperature of moisure (water) in Propane liquid? can I use The Psychrometric chart?
2. Henry's law constant for water?
24-07-2006, 09:18 AM #2
Re: Moisture in Propane Liquid
Refrigeration grade propane doesn't have any appreciable water content.
24-07-2006, 10:18 AM #3
Low grade propane may do though. You could send a sample for analysis, or a simple field test is called the valve freeze test, where you discharge some propane through a valve and time how long it takes to freeze up, the wetter it is the quicker it will freeze. This would be an IP/ASTM type of test, obviously you need the right type of valve etc., but it will all be in the relevant standard. It's not very accurate but it's the easiest.
Just looked it up, see ASTM D2713-91 (2001) for details.It's a lovely day to pump some gas
24-07-2006, 11:22 AM #4
It does have ppm level of moisture.
24-07-2006, 04:12 PM #5
I have a section of an article someone gave me - no idea where from though:
Temperature ppm saturated level in liquid propane
-40C 3ppm
-30 5
-15 13
+6C 44
+15 75
+30 173
+45 360
Note that for low temps (below zero) the vapour holds about 20 times more moisture than liquid, this is about 10 times around ambient temperature. I also have some data from GE Sensing which shows higher saturation levels (liquids) - note sure which is more accurate.
Hope this helpsIt's a lovely day to pump some gas
Suction gas <-> liquid line heat exchange and performance gains
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 18-05-2010, 01:52 PM -
Liquid line for multi evaporators
By Kevin Yeo in forum Supermarket RefrigerationReplies: 1Last Post: 29-12-2005, 03:29 PM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM -
Liquid Refrigerant Pumping
By bersaga in forum Technical DiscussionsReplies: 34Last Post: 09-08-2003, 08:07 PM
