Thread: Split Capacitors on Resi AC
24-07-2006, 01:44 AM #1
I was wondering if there is any damage to be caused by leaving an oversized capacitor on a fan or compressor after an emergency repair. Like a 45 /7.5 when the original was a 35/5. .
24-07-2006, 03:50 AM #2
Re: Split Capacitors on Resi AC
Originally Posted by crisrsLast edited by wambat; 24-07-2006 at 04:13 AM.
27-07-2006, 01:01 AM #3
I can say from my experience with my system shutting down during hot outdoor temperatures, that the larger sized capacitor will cause the fan motor to run hotter and consume more power. You can expect the compressor to do likewise. Just as you're describing, I made an "emergency repair" and forgot about the excess sized capacitor. It took a long time to figure out the cause of intermittent shutting down.
My recommendation is to locate the correct part that has been engineered for your application.
Pressure testing for leaks on split a/c systems
By mrchatts in forum Air ConditioningReplies: 46Last Post: 08-04-2010, 10:02 AM -
panasonic 3 phase split
By mike live in forum Air ConditioningReplies: 18Last Post: 18-08-2006, 11:54 PM -
can a r22 split system condensing unit be used to cool a display fridge
By tsangep in forum RefrigerantsReplies: 8Last Post: 20-05-2006, 04:21 PM -
LG ducted split
By Abe in forum Air ConditioningReplies: 20Last Post: 08-06-2005, 07:19 PM -
Capacitors
By Abe in forum Trouble ShootingReplies: 5Last Post: 13-01-2002, 03:08 PM
