    Andy2no's Avatar
    Andy2no Guest
    Hello To everyone need some advice
    I have a nine year old Zanussi ZFC 61/27 Single compressor Fridge Freezer Which has developed a problem with the fridge compartment it is too warm lowest temperature achieved is 5.8 oC The freezer is -24oC Can anyone give me some advice on how to sort this problem out. PS Ice does form on the backplate of the fridge.
    Apr 2001
    2,099
    27
    Re: Hello To everyone need some advice
    Me thinks the efficiency of the compressor is reducing, hence noticeable in fridge compartment which is the last section of evaporator surface.
    A Fridge technician requires to check pressures via some access port, if fitted.
    Andy2no's Avatar
    Andy2no Guest
    Thanks for the info
    Jul 2006
    uk
    58
    14
    Firstly defrost the unit for 24 hours, then if still have a fault after 8 hours of running time ........
    If its an R12 unit, then time to replace it.
    IF its an R134a unit, make sure the door seal is good,then if still faulty i would recover the old refrigerant and purge nitrogen free oxygen through the system, (checking for blockages), change the dryer and recharge the unit with R134a.
    maybe change the compressor at the same time,
    should cost around £150 (new comp)
    hope this helps
  1. Your advice to Split Air buyers.
    By mick2me in forum Air Conditioning
    Last Post: 15-07-2006, 04:59 PM
  2. Good advice!
    By shogun7 in forum Chit Chat & Service Stories
    Last Post: 03-09-2004, 01:06 AM
  3. Help, advice needed.
    By josewick in forum Trouble Shooting
    Last Post: 30-10-2003, 09:27 PM
  4. Any advice how to cure this blocked system?
    By moh in forum Trouble Shooting
    Last Post: 25-06-2002, 08:35 PM
