22-07-2006, 07:14 PM #1
Little Help with a Aquarium Chiller
I'd like to Build one not becuase i'm cheap but for the Challange, I do need one!
I pickup a couple window Air units from Work for $10 they are 220v both 12500 BTU i think this would be over kill but should be able to Impervise
I could mod the evaporator into a Box but if down the road i want to use the windows air unit or sell it i can
What i would like to do is make a coil that can be droped in the water i have seen these but can't get a very good look at one, from what i see is theres only one tube (low side) going in the water? HOW are they doing that? i don't see a High Side line at has to have one!
Any Help would be geat
22-07-2006, 07:23 PM #2
Re: Little Help with a Aquarium Chiller
the cappilery is inside the suction line, I'll direct you to a site where we mod thes things all the time.
http://www.xtremesystems.org/forums/...play.php?f=155 < This is the place for you.
22-07-2006, 07:35 PM #3
Also a good day to you Superbee.
22-07-2006, 08:14 PM #4
Hello Peter.
Where can i buy this line at?
or do i have to make it, that would be a little harder
or maybe buy just the coil only
One of the unit has a copper evaporator i beleave that the other is ALU
From what i under stand is you can't install the copper in the tank it will kill the fish over time?
I rember the Overclocking Days that was a couple years ago for me got my 2.8 to run stable at 4.445 for 96 hours
22-07-2006, 08:30 PM #5
the line is assembled by the installer; Copper I don't know, no better then Alu; but you can buy stainless steel evap coils from eBay and such.
You could buy a sealed off stainless steel pip section and wrap the copper around it to make a chill cell. lots of ways of making an isolated coil.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
how to make aquarium chiller ?
By ame in forum New TechnologiesReplies: 17Last Post: 05-11-2007, 04:36 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
closed loop chiller
By bender in forum Trouble ShootingReplies: 8Last Post: 02-01-2003, 01:32 PM
