Results 1 to 20 of 20
20-07-2006, 08:26 AM #1
Portable AC cuts off power to other appliances
Bought myself a portable Airforce BTU 12000 from B&Q.
Problem:
When the cooler stops and restarts (when the set temp has reached), it cuts off power to all other plugged in appliances such as my computer , table clock etc.
Whats wrong?
20-07-2006, 09:55 AM #2
Re: Portable AC cuts off power to other appliances
Your supply is overloaded.
Takes a licking, keeps on ticking.
20-07-2006, 03:33 PM #3
The other appliances do not lose power for good because they recover immediately. eg: the PC restarts automatically.
Also, this does not happen when I manually stop and start the machine.
And the AC is the only appliance connected to the socket in the room. Is it the tripper switch in the mains that is responsible and what can I do ?
20-07-2006, 04:14 PM #4
Try it on another socket in the house if it does the same, take it back and demand a refund.
Pocket the cash or buy a better machine.
If it still doesn't work properly and you can't get a refund, complain to the Trading Standards Office.
Your most likely form of complaint is breach of the EMC rules. i.e. it should not affect an adjacent appliance.
If there was a problem with your breaker it would go out and stay out..
Sodd's the name...... Law's the game.
Established 1791 - still going strong.
20-07-2006, 09:22 PM #5
Take it back to B & Q pronto and give Mr Millenium a ring
20-07-2006, 11:49 PM #6
Originally Posted by Sir Josiah Sodd
Could you give me a link to the EMC rules please. Dont know anything about this.
21-07-2006, 09:06 AM #7
Originally Posted by Manhar
http://ec.europa.eu/enterprise/elect.../emc/index.htm
ALL electrical equipment MUST comply by law..
21-07-2006, 01:37 PM #8
Starting the compressor takes so much current that you have a voltage drop that triggers the power supply to the other voltage sensitive electronics.
21-07-2006, 01:59 PM #9
Originally Posted by Peter_1
Most probably, it comes under short term transience (flicker) in the EMC regulations.
There are limits that the emitting device must not reach and likewise the adjacent equipment must have certain immunity limits.
The owner previously said that it starts OK manually; the problems occur when the device restarts under its own control.
If it is an electronic control device, there may be transients floating about. If they are enough to disturb an adjacent device of any kind it’s wrong – (and illegal) I’d recommend taking the thing back.
21-07-2006, 02:31 PM #10
Also "Sale of goods act" says that it must be fit for purpose - which it blatantly is not.
Take it back to B&Q
Paula
21-07-2006, 06:20 PM #11
this guy is in the US don't forget.
21-07-2006, 06:40 PM #12
....Is he?
Just thouhgt he got his flags mixed up....
what a shame, a long way to take it back!.
21-07-2006, 07:42 PM #13
Unless I'm mistaken the gentleman said he bought the unit from B&Q, which I'm assuming is in England somewhere as it seems to be a very popular topic.
I can't comment on why the flags are mixed up, but...
Originally Posted by Mr. MG Pony
21-07-2006, 07:53 PM #14
Looking at his profile, he is a student in Jolly Ole England, and is a Yank.
So he probably purchased it in England, but it sounds like he is border line on the load for that circuit. Just not enough to trip it.
21-07-2006, 07:55 PM #15
I'm sure if he had all of your years of experience he would not have asked.
22-07-2006, 07:08 AM #16
No I was making the comment as to the laws, as the trade laws are all differant that was the only thing I was pointing out. If the flags are mixed up only he can answere that,
22-07-2006, 07:11 AM #17
and I don't have a ton of years experiance, I just have the benifit of learning well and some Tech friends one a civil engineer, and another an old fapliance repair guy.
Any case that is aside from the point I was trying to make, which is when answering we need to keep it relitive to the country they are in, so obviously if he is in england then england laws are what we aut to go by, thats what I was meaning by my post.
22-07-2006, 12:49 PM #18
2/The socket is off a ring main and there is already a high load on it
Any fridge system of this nature will be easier started when cold (pressures are equilized) when running and start/restart it will take more current to start
Try a different supply (off a different fuse or breaker on your consumer unit).
Hope this helps
Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
22-07-2006, 01:19 PM #19
Originally Posted by frankTakes a licking, keeps on ticking.
22-07-2006, 01:25 PM #20
Originally Posted by slingbladeTakes a licking, keeps on ticking.
Daikin KRP2A61 Card Power consumption
By EddieC in forum Air ConditioningReplies: 5Last Post: 19-08-2006, 04:08 PM -
what is a capacitor power pack ?
By Bahaaeldeen in forum Air ConditioningReplies: 2Last Post: 11-05-2006, 12:56 PM -
power factor correction
By marley821 in forum Technical DiscussionsReplies: 4Last Post: 06-05-2006, 08:29 PM -
NEW 3-Phase IGBT Inverter Power IC
By theberes in forum New TechnologiesReplies: 14Last Post: 01-03-2004, 01:10 AM -
EEV's and their usefullness for low power applications
By DaBit in forum New TechnologiesReplies: 7Last Post: 18-08-2003, 09:11 AM
