Results 1 to 16 of 16
Thread: R12 to R134a
    Jul 2006
    uk
    58
    14
    R12 to R134a
    FIrst would like to say what a great forum,
    This is my first entry, so sorry if i mess up !
    ex Hotpoint engineer of 24 years, always done fridges/freezers,
    but only the electrical side of things till last year for which i now involve myself in the refrigerant cycle.
    Im converting a fridge/freezer that is R12 to R134a,
    Thats a new R134a compressor and dryer.
    The unit.. R12 specifies 280grams, not sure how much R134a to charge ????
    Thanks for all info.
    fireblade
    Apr 2001
    2,099
    27
    Re: R12 to R134a
    One way is to charge it till the low pressure pipe starts sweating....Thats the line back to the compressor.
    Ensure no liquid gets back into the compressor, watch the "ice line"
    Will take a little time to charge it correctly.........called " critical charge"
    Jun 2005
    Stoke on Trent
    588
    Re: R12 to R134a
    Use R49 instead and reduce charge by 8 - 10%.
    Sep 2005
    uk
    499
    21
    Re: R12 to R134a
    A good starting point here is to charge 280g of 134a. if it goes BANG you were wrong. i dont think this is at all likely though.
    Takes a licking, keeps on ticking.
    Jan 2006
    Adelaide , Australia
    192
    Re: R12 to R134a
    Just use same charge as the "OLD GAS " if the compressor is a ball of ice after its down to temp you have overcharged it and adjust accordingly .
    Jul 2006
    uk
    58
    14
    Re: R12 to R134a
    Thanks for the info guys
    will let u know the outcome
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: R12 to R134a
    Please use MP39 or similar.
    Jul 2006
    57
    Re: R12 to R134a
    I reckon you will need about 250g of R134a
    Apr 2006
    41
    1,620
    Re: R12 to R134a
    you do realize that you need to change the oil to POE right?
    Ireland
    47
    26
    Re: R12 to R134a
    Quote Originally Posted by The MG Pony
    Sure he's changing the compressor!
    new compressor comes with new oil.
    Jun 2005
    Stoke on Trent
    588
    Re: R12 to R134a
    Quote Originally Posted by Langer
    Thats fine as long as it is a R134a compressor as there are still some R12 compressors for sale, electrolux for one still sell them.
    Ireland
    47
    26
    Re: R12 to R134a
    Quote Originally Posted by Andy W
    If he's changing out an R12 pot for a 134a, there's no
    need to do anything else. Just fit the 134a pot in, you're not going to flush out a Domestic and change the cappillary line.
    Jun 2005
    Stoke on Trent
    588
    Re: R12 to R134a
    As a precaution I would blow the system through with OFN before fitting the new compressor and filter drier.
    Ireland
    47
    26
    Re: R12 to R134a
    True, but i woundnt spend too much time on it though.
    'Tis only a domestic after all.
    Jun 2005
    Stoke on Trent
    588
    Re: R12 to R134a
    Doesn't take long, I use a VAX 4 access fitting attached to a piece of 1/4" ID plastic hose, this is my quick coupler for blowing through pipe work with out having to solder stubs on first.
    Apr 2006
    41
    1,620
    Re: R12 to R134a
    If a job is worth doing it is worth doing right, if not then why do it at all?
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. Pressure Transmitter R134a Setpoints
    By cooltrain in forum Technical Speculations
    Last Post: 28-02-2005, 09:05 AM
  3. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
  4. R507 in an R134a compressor: system design
    Last Post: 01-05-2003, 09:25 AM
  5. Minimal required R134a speed in suction line
    By DaBit in forum CPU Overclockers
    Last Post: 08-05-2002, 05:19 AM
