Thread: Daikin EUWA50 Chiller
18-07-2006, 07:27 PM #1
Has anyone worked on an EUWA50 chiller?
I had a high pressure problem which I sorted out but then the oil switch light started showing without the chiller even running. The wiring circuit was extremely difficult to follow. Couldn't get the thing to run.
Returned next day to start affresh. Switched on and it worked first time.
What's going on?
PB
18-07-2006, 08:28 PM #2
Re: Daikin EUWA50 Chiller
I haven't worked on one of these chillers, but the problem you described sounds like it is wiring related.
Did the oil safety trip after the high pressure switch tripped?
If so, the opening of the high pressure switch must have energized the resistance heater in the oil safety switch.
That should be fun to sort out it that's the case.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
Daikin Analyzer
By marc5180 in forum FundamentalsReplies: 10Last Post: 02-08-2008, 07:15 PM -
Daikin Controllers
By airefresco in forum Air ConditioningReplies: 5Last Post: 15-05-2008, 08:08 AM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM
