Thread: Your advice to Split Air buyers.
14-07-2006, 07:19 AM #1
Following the threads here about, professional installers concerns over DIY systems.
What would your advice be to anyone who was considering buying units for DIY fitting?
14-07-2006, 10:04 AM #2
Re: Your advice to Split Air buyers.
Originally Posted by mick2me
One example recently a 600kW chiller I was 20% more expensive, but I told the customer that it was no mistake that the other company was taking short cuts. On investigation the other chiller was using 30% plus more energy for the same duty, had a smaller foot print and was 2500kg lighter. Basically a big compressor on small heat exchanger. The other chiller would have been cheap to buy but way more expensive to run and more likely to breakdown.
Also if you want to fit the unit yourself, consider a chiller water (Wet) system. No gas lines, same wall ceiling and concealed celing units and heat pump heating possible also
http://www.rhoss.com/schedaprodotto.asp?scheda=14
Or what we in the trade call window rattlers, a through the window or wall unit, a single unit that does the job
There is also a DIY split that has push in fittings on the pipes.
http://www.argoclima.com/
Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
14-07-2006, 10:21 AM #3
Originally Posted by Andy
14-07-2006, 09:16 PM #4
Yes good advice both, but I expected reasons why they should not do it themselves, I was talking of units that need refrigeration lines connecting.
Not the push fit Jobbies, from B&Q.
I think my first advice would be pay the extra for an inverter from a reliable manufacturer. Short term expence = long term energy savings, queiter unit, less wear an tear on parts by cycling on and off etc.
The next ensure that if they are not capable of doing the refidgeration or electrical side, ensure that they can get expert help at a fair price, before they buy the unit.
15-07-2006, 10:32 AM #5
I would say the domestic A/C market in the UK is quite a new one. Mainstream contractors are not geared up for this type of application. In time specialist domestic contractors will establish themselves, but at the moment we are in limbo land.
It costs to train staff, put vans on the road and to insure them, never mind the on going training to keep up with market changes and legislation.
If you have a labour force set up to install quickly and effeciently in a commercial enviroment, and you are stretched to handle the work load in the summertime, you will be looking a premium to fit splits in an enviroment that you are unfamiliar with, or to fit splits that someone has bought on the cheap, which are an unknow quantity.
Hope this helps
Kind Regards AndyLast edited by Andy; 15-07-2006 at 05:43 PM.
15-07-2006, 04:59 PM #6
Perhaps employ an extra apprentice to carry out such work.
With appropriate caveats for the customer about DIY units.
In fact my missus is looking for a new job, all offers on a postcard please.Last edited by mick2me; 15-07-2006 at 05:01 PM.
Pressure testing for leaks on split a/c systems
By mrchatts in forum Air ConditioningReplies: 46Last Post: 08-04-2010, 10:02 AM -
panasonic 3 phase split
By mike live in forum Air ConditioningReplies: 18Last Post: 18-08-2006, 11:54 PM -
can a r22 split system condensing unit be used to cool a display fridge
By tsangep in forum RefrigerantsReplies: 8Last Post: 20-05-2006, 04:21 PM -
Cooling condenser of split with condensate from evaporator
By smileypete in forum Air ConditioningReplies: 11Last Post: 10-07-2005, 08:21 AM -
LG ducted split
By Abe in forum Air ConditioningReplies: 20Last Post: 08-06-2005, 07:19 PM
