Results 1 to 9 of 9
13-07-2006, 05:41 AM #1
started to make an evap for my chiller
http://www.xtremesystems.org/forums/...d.php?t=106780
So what you think so far, I'm making an SLHX directly on the cell to keep it highely compact, once don and pressure tested I'll finnish sealing the PVC shell and then insulate it with expanding foam, and a temp senore will be intergrated into the shell
13-07-2006, 10:29 AM #2
Re: started to make an evap for my chiller
Thats nice bud, but what is it that it does? it just looks like a pointless piece of refrigerated drainpipe to me.
Takes a licking, keeps on ticking.
13-07-2006, 07:31 PM #3
lol. thats because I haven't built in the fluid carrying system yet; it is a chiller cell, that should handle a good amount. I'm setting it so the water rotates inside all around the evap surface.
14-07-2006, 01:18 AM #4
Do you mean an evaporator?
j p g
14-07-2006, 02:44 AM #5
ya just abbreviated to evap.
20-07-2006, 05:19 AM #6
You'd end up with better heat transfer if you put another pvc tube inside the coil. Top view would be donut shaped. Brine would only flow between the two pvc tubes.
Will melt ice for $101/hr
20-07-2006, 06:38 AM #7
I'm seting it to have spiral flow internaly and thats basicly what I'm doing, haven't started that phase yet, just finnished the refrigeration plant and it got lots of frost fast hehe.
22-07-2006, 08:34 PM #8
So what you guys think, looking Ok? I'll post technicle details when it is more finnished.
22-07-2006, 08:44 PM #9
And as to the sewer pipe, here is the full story on that!
There is going to be a second barb put in when I get to a place that has them on this damned coast, and that is a stainless steel thermister 6K at 21C and a 714 Op amp signal conditioner.
I'll be using a DeltaT for temp control system to lock it at -3.3Evap.Last edited by The MG Pony; 22-07-2006 at 08:51 PM.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
how to make aquarium chiller ?
By ame in forum New TechnologiesReplies: 17Last Post: 05-11-2007, 04:36 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Evap motor no come on
By Apprentice in forum Technical DiscussionsReplies: 13Last Post: 04-12-2003, 04:07 PM
