17-01-2002, 08:37 PM #1
That's true, Frank. But these two factors must be considered for each of the heat exchangers. If the incoming tap water is above 15C, the chiller doesn't stand a chance. In fact, to achieve the 15C target, the tap water should be 10C or less.
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
High temperature particulate cooling
By Reeferjon in forum IndustrialReplies: 13Last Post: 19-09-2005, 12:12 PM
