Results 1 to 10 of 10
    Dec 2020
    South Africa
    1
    Bitzer csh9573-180 screw demister pipes broken
    Good day everyone
    I have been rebuilding piston and screw compressor for many years.
    At the moment I am busy with 4x Bitzer CSH9573-180 screw compressors for 1 client.
    All these compressors run on R134A water cooled chillers
    When I opened the compressors all the parts, casing and components looked immaculate except for a broken demister pipe.
    I found 2 of these compressors (from different sites) have the same problem. The demister (Built-in oil separator) discharge pipe has broken.
    I have attached pictures (Below)
    Has anyone else experienced this or have any ideas as to the cause?
    Keep in mind that all other components are in very good condition and this is the first time the compressors have been opened.
    regards
    Andrew
    Feb 2011
    scotland
    456
    Re: Bitzer csh9573-180 screw demister pipes broken
    Have a careful look at the crack surfaces, it might show how it failed.
    Could it be a defect in the material at the weld point has grown into a crack by fatigue?
    Could temperature changes or vibration be cyclically stressing an area?
    Interested to hear about opportunities to learn - linkedin.com/in/s34nf
    Sep 2009
    Iran
    66
    672
    1
    I think it comes from temperature changes.
    it is in discharge side and it is hot about 80 C
    If system has liquid back from Evaporators in large amount suddenly frequency and does not evaporate in through going inside of compressor wiring ,
    First it hit this Elbow and we have tension from changing temperature there .
    MBC
    Oct 2003
    5,630
    34
    Perhaps contact better Bitzer Germany... they want to know special issues with their machines.
    Sep 2009
    Iran
    66
    672
    1
    Hi peter
    I asked 2 or 3 times some question but they referred me to his inter national manager and he is no response .
    last time I asked about R - 410A , Can I use in HSN types ?
    495
    21
    Hi I think its when the compressor is fully loaded to quick it causes vibrations and the demister pipes crack
    Sep 2009
    Iran
    66
    672
    1
    We should believe our community power ( this site )
    After more than 5 E-mails and in the end I pointed here , today Bitzer response for my question .
    MBC
    Jul 2006
    74
    865
    26
    What was their response?
    Sep 2009
    Iran
    66
    672
    1
    this is :
    Thank you for your interest in BITZER Products.
    HSN machine usually can’t be used with R410A due to the machine- design pressure and the high discharge pressure of R 410A
    More information you can find under
    https://www.bitzer.de/shared_media/h...-GB/index.html
    https://www.bitzer.de/websoftware/De...=en&country=gb
    Feb 2024
    new york
    2
    Although the compressors are being opened for the first time, it's possible they experienced fatigue due to vibrations, pressure fluctuations, or other operational stresses during their service life. This fatigue could have contributed to the eventual failure of the demister pipes. It's also important to consider any external factors that Ultra high-speed angular contact ball bearings might have caused damage during transportation, storage, or installation. Even minor impacts or improper handling could have contributed to the cracks.
