    Aug 2023
    Australia
    3
    Removing Daikin PCB - RZP125DV1
    I am trying to remove PCB PC0104H-1 from Daikin RZP125DV1
    Have disconnected plugs and wiring and the two screws
    Board only moves a few millimeters horizontally but will not lift up
    Still seems to be being held down around where the screws were
    If any one has any ides please advise what is required to release the board
    CP
    Oct 2001
    Nottingham UK
    5,667
    Re: Removing Daikin PCB - RZP125DV1
    Here's a link to the instructions
    https://www.manualslib.com/manual/86...age=225#manual
    Aug 2023
    Australia
    3
    Hi Frank
    Really appreciate your link to the manual
    Unfortunately I've done what it says relating to removal of PCB and it will not lift out
    With a bit of pressure the board moves horizontally about 5mm left to right, and front to back
    It will also rotate within the limits of the plastic switch box and seems to pivot between where I have removed the the two screws - probably a closer to the left one.
    I can lift the edges of the board up a little as it flexes, but it still feels locked down around the mounting screw holes
    Just wondering if you have any ideas what maybe holding it down and how to release it
    Colin
    Feb 2008
    502
    21
    it might be stuck on heat sink paste
    Oct 2001
    Nottingham UK
    5,667
    Have you carried out Step 3 on the next page of the manual?
    Aug 2023
    Australia
    3
    Thanks for your help
    The board was just stuck on the heat sink paste and I have been able to remove it
    Oct 2001
    Nottingham UK
    5,667
    Thanks for the update
