Thread: City Multi
    Jan 2005
    Ireland
    43
    111
    21
    City Multi
    Hi guys / gals
    Function List
    Anybody have the function list for city multi NOT Mr Slim (1 to 11) ?
    Codes start at 32, can’t find it anywhere.
    Key cards
    Hotel application with key card adapters. Never used them before so assumed from wiring diagram that I should use a NO contactor .There is an existing install on site which I checked and that’s the way they wired them. However I soon realised that the contact needs to be NC and when a guest inserts the keycard it opens the contact and unit can be operated . Removing the card closes the contact preventing operation.
    Is there a way of changing this? Thanks in advance
    Somerset
    69
    4,716
    Re: City Multi
    Hi ronaldo9 .I have several manuals which may or may not be relevant. But i have to admit I am a little unsure as to which function lists you are referring to? I cannot find any that have designations 1 to 11! sorry.
    So I have drawn a blank sorry. Hopefully someone has been able to help? And the keycard dilema does sound interesting.
    Good luck Grizzly
    Jan 2005
    Ireland
    43
    111
    21
    Re: City Multi
    Cheers Grizzly
    Mitsubishi confirmed key card kit needs a Normally closed contact to operate, so controller is operational when contact is open.
    Functions on city multi units are all done from dip switches on indoor board. Just the usual stuff like filter duration and thermistor control.
    Thanks again
    Know Better = Do Better
    Somerset
    69
    4,716
    Re: City Multi
    Hi dip switch setting is what i have. Leave it with me and I will sort for you.
    Grizzly.
    Somerset
    69
    4,716
    Re: City Multi
    Hi. Manual links sent by several means. Hopefully you will get something and it is of use. Regards Steve.
