Thread: chiller Sanyo
    May 2020
    belgium
    15
    chiller Sanyo
    Hello
    i have a chiller Sanyo SCP-AR301E8
    fault code E41 and E02
    I cannot find something on the internet
    Who can helps?
    Greetings Fernando
    Jun 2023
    Re: chiller Sanyo
    Maybe the customer will have the op. and maintenance manual? or it might be inside the chiller?
    Failing that .....phone Sanyo agent/supplier who should have access to fault codes or tech support number
    While you wait perhaps check the basics, good voltage on phases, flow switch/meter on hydronic side, if there is sufficient charge for LP switch/sensor to operate etc.....
    May 2006
    Hayling Island, UK
    143
    21
    Re: chiller Sanyo
    Hi csrbv,
    If you are still after information I have install manual and service manual and parts list for this Sanyo Chiller.
    Let me know if these would be useful to you.
    Loops
    May 2006
    Hayling Island, UK
    143
    21
    Re: chiller Sanyo
    Oh and the E41 is poor water flow - you should be getting 5.33m³\hr
    I can't find anything on E02 error code.
    Loops
