    Oct 2022
    Italia
    49
    Unhappy Condenser inlet is too big?
    Hello! I've noticed my 350W condenser have huge inlet, like 8mm OD. I cannot fit 8mm and I don't dare swaging it because the thickness appears to be already too thin, even if the thing is rated for 300+ PSI. I think I'm supposed to fit the 5mm OD tube because it's the correct size for the compressor's discharge but how am I going to fit a 5mm OD in that huge inlet? I would have to put a lot of brazing, but wouldn't it make for a weak joint? I thought I studied that the gap must not be too wide, just enough to have a capillary effect that coats the inside of the joint. So what gives?
    Feb 2011
    scotland
    458
    Re: Condenser inlet is too big?
    A reducer, if you can get one that goes from 8 to 5 mm. Have one made?
    Make your own reducer with a series short length of pipe increasing/decreasing in diameter, expanding the pipe if needed or to try and reduce the number of steps.
    Or a rough method, crimp the edge of the 8mm pipe at one point around the 5mm pipe. Probably want to heat the 8mm pipe up first though.
    I guess it depends on if it needs to look good or if its just an experiment.
    Interested to hear about opportunities to learn - linkedin.com/in/s34nf
    Oct 2022
    Italia
    49
    Sorry I was being an idiot. Actually if I push a little the 8mm does fit pretty snuggly. No swedging required
    Apr 2023
    3
    You are right that the gap should not be too wide. However, you can bridge the gap between the 8mm OD tube and the 5mm OD tube with a reducer fitting. This would allow you to make a secure connection without risking weakening the joint. Additionally, you may need to apply flux to ensure that the brazing process properly seals the joint. How to make a chat app 1. Choose a platform: Decide what platform you want to use to create your chat app, such as Android, iOS, or web. 2. Design the user interface: Create a user interface for your chat app that is easy to use and intuitive. 3. Choose a messaging protocol: Select a messaging protocol such as XMPP or WebSocket to enable communication between users. 4. Implement the backend: Create a backend for your chat app that handles authentication, user management, and messages. 5. Add features: Add features such as chat rooms, file sharing, and notifications to make your chat app more interactive and engaging. 6. Test and deploy: Test your chat app thoroughly and deploy it to a hosting provider.
    Oct 2022
    Italia
    49
    Hi Houston, thanks for your reply. I believe some brazing rods have the flux around them, expecially the high silver content ones used in refrigeration, am I correct?
    Oct 2003
    5,630
    34
    Your acid flux will enter inside the tubes contaminating the refrigerant... use silphos rods.
    Cut a small end pipe as in your 1st picture, insert it in the condenser and the insert your 2nd smaller pipe in this small end.
