Thread: dunham-bush split aircon unit
05-07-2006, 04:58 PM #1
we recently had a split/unit installed,wall mounted below window, model grt02b, ok on heating but very dissappointed for aircon purpose seems to heat room up rather than cool, never had aircon before so completely out of water what to expect, engineer who installed not available, any help would be appreciated, conservatory has celsius glass roof size is 10ft wide, 15ft long sorry still on imperial
05-07-2006, 09:34 PM #2
Re: dunham-bush split aircon unit
Hi Philly, welcome to the site.
I'm sorry to say that I can't find any information about AirCon units from Dunham Bush on any of their websites.
As to what you should expect, well it should blow cold shouldn't it !!
How recently was it installed and was it fitted by a private tech or supplied and fitted by a company?Brian - Newton Abbot, Devon, UK
06-07-2006, 03:09 PM #3
thanks for the reply, supplied by company who installed conservatory, i suspect they just subcontracted the work to him, i have tried his mobile/home no but to no avail, looking at manual supplied recommends lowest setting at 17c and at the time im sure he said dont run below 19c. asked engineer at time if adequate to meet needs and was assured the unit would be more than expected,given delays with completion with conservatory, it was completed in october, hence never had oppertunity to test unit.
06-07-2006, 07:48 PM #4
How many Kw's or btu's/hr is the machine?
06-07-2006, 10:24 PM #5
I would return to the supplier of the conservatory, they sold you the complete package I imagine - glass, walls, roof, aircon.
If they did then they carry the warranty etc for the package.Brian - Newton Abbot, Devon, UK
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 02:42 AM -
Check RooM Aircon Outdoor Unit gas pressure
By ongahhuat in forum Air ConditioningReplies: 16Last Post: 29-08-2006, 12:12 PM -
Split unit (Recommendations)
By Smokey in forum Air ConditioningReplies: 7Last Post: 26-07-2006, 10:04 PM -
can a r22 split system condensing unit be used to cool a display fridge
By tsangep in forum RefrigerantsReplies: 8Last Post: 20-05-2006, 04:21 PM -
Dunham Bush Chillers
By frank in forum Air ConditioningReplies: 14Last Post: 11-08-2002, 12:13 AM
