Results 1 to 1 of 1
17-09-2022, 12:46 AM #1
CO2 transcritical KV valve calculation
Hi, I'm tryin to calculate pressure drop across a valve when the fluid state is transcritical. On discharge side (before gas cooler) and on gas cooler return. Valve KV value is known. P1, P2 and massflow are known. I can find the formula for both superheated vapor and saturated liquid, but didn't find anything for transcritical state. thank you,
https://www.burkert.ca/en/Service-Su...uid-Calculator
