Thread: Daikin VRVII loading problem
26-09-2007, 12:40 PM #1
I have a situation where there is an REYQ46 installed and there is one zone which is a 125 fcu which is on the west zone which has a high solar load. My problem is when all other zones are satisfied and this is the only zone calling for cooling the condensing set does not respond. It only ramps up when I turn other fcu set temps down to give it load does it respond. Any ideas??
26-09-2007, 05:27 PM #2
Re: Daikin VRVII loading problem
Does the affected unit cool if the rest of the system is running?
Is this a new install or an existing one with a new fault?
26-09-2007, 08:09 PM #3
Does the outdoor unit 'see' this fan coil. Have you done a fan coil count on the outdoor pcb?
01-10-2007, 01:27 PM #4
the fcu inquestiondoes function correctly when other fcus are running. Problem seems to be when calling for cooling on its own. It is registering at the outdoor unit
24-11-2007, 12:52 AM #5
24-11-2007, 12:56 AM #6
24-11-2007, 02:35 PM #7
Problem with an inverter compressor in V.R.V system DAIKIN R 407
By Harris Greece in forum Air ConditioningReplies: 10Last Post: 24-11-2007, 12:53 AM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
!!big Daikin Problem!! Codes,u4,pj, And E0
By airconengineer in forum Air ConditioningReplies: 21Last Post: 31-05-2007, 09:04 PM -
Daikin problem
By Jambo in forum Trouble ShootingReplies: 4Last Post: 28-07-2006, 07:42 PM
