Thread: low duct temperature
14-06-2022, 03:23 AM #1
I have a 2.5 ton split unit. New evaporator last year. It all worked fine until now. However now I cannot get lower than 65 degrees out of the duct anywhere in the house. This was in the 50's before.
Suction 125
head 280
Condenser unit is about 4 years old. Seams to be working good.
I am at a loss.
Rick
14-06-2022, 07:35 AM #2
Re: low duct temperature
Pressures are meaningless without knowing what refrigerant you are talking about.
Other parameters such as air entering, air leaving, room temp etc. also help.
14-06-2022, 07:14 PM #3
15-06-2022, 06:21 AM #4
I would suspect that you have a refrigerant shortage.
The only way to tell is to recover and check the amount against the nameplate charge.
