Thread: dakin controller
27-06-2006, 07:39 PM #1
dakin controller
looking for some help with the field settings on a dakin controller (brc1d528) have changed the field setting for the remote thermostat sensor to off (not use) , but i'm contolling 2 splits off one controller . Does this adjustment mean that the splits will work off there air on temp individually. any help would be greatful.
27-06-2006, 07:43 PM #2
Re: dakin controller
Originally Posted by mike live
27-06-2006, 07:44 PM #3
yes there in the same room.
27-06-2006, 07:55 PM #4
2 x split systems on one controller will each signal the outdoor units individually on achieving set point.
Sorry about the previous question, I first thought you were controlling a twin split off one controller - it's been a long day 14 hours today and a total loss on a fridge load last night
27-06-2006, 08:04 PM #5
cheers frank for the replies.
would there be a way of forcing an inverter system to run at 100% so to check the running amps and gas pressures or have i completely got the wrong idea on inverter systems
27-06-2006, 08:12 PM #6
Put the unit into test mode which will force the system to override the stat setting.
With the inverter systems, it may take some 10/15 minutes for the comp to ramp up to full speed - have patience and keep an eye on the gauges. The pressures seem to hang steady for ages then slowly increase.
Micro-cool controller
By bernard in forum Supermarket RefrigerationReplies: 6Last Post: 25-08-2006, 07:10 AM -
Help with new electronic refrigerator controller !
By EngiGal in forum New TechnologiesReplies: 17Last Post: 08-04-2006, 07:39 PM -
Controller wiring
By Mickvee in forum Air ConditioningReplies: 2Last Post: 30-12-2005, 02:04 AM -
Temperature controller which operates down to -100C/-150F
By DaBit in forum IndustrialReplies: 4Last Post: 27-10-2003, 10:43 AM -
Fan Controller
By Abe in forum Trouble ShootingReplies: 4Last Post: 12-01-2002, 02:21 AM
