Results 1 to 13 of 13
    Jun 2006
    cambridgeshire
    31
    which unit do i need??
    hello all, can anyone tell me what size unit i would need to cool, and heat, my conservatory?
    it is south facing and measures 10'6 x 10'6 ????
    thanks
    Oct 2003
    5,630
    34
    Re: which unit do i need??
    May I ask to remove all your double posts please?
    Jun 2006
    cambridgeshire
    31
    sorry,frank did delete some of them, first time on and didnt realise it could be seen everywhere by posting in one forum. and wasnt sure where to put it !!!!!!
    Oct 2001
    Nottingham UK
    5,667
    No problem acgibo - thank you for your response
    Enjoy the forum
    Oct 2005
    nottingham UK
    109
    Hi can i ask what peter meant, im a bit new to this
    Oct 2003
    5,630
    34
    Well Davej, you posted the same question in different sections and the chance that someone answers then you question is nil.
    We take mostly an average load of 100 to 125 W/m².(32 to 40 BTU/ft².h), air change min 4 to 5 times the space volume.
    If the units needs also to heat the building, then a well isolated building needs +/- 50 W/m³ (171 BTU/h/35 ft³)
    Hope I didn't converted the wrong way.
    What are SI units so much more comfortable
    In fact, I even didn't understand the 10'6
    10' is for us 10 minutes.
    Oct 2001
    Nottingham UK
    5,667
    Quote Originally Posted by davej
    Hi Dave
    On the forum there are lots of different areas to post, Refrigeration, Air Conditioning, Technical, Ye Old Wives Tales etc.
    When posting a question, it is better to chose the appropriate section for your question.
    Some new posters choose the wrong section or think that it is a good idea to 'multiple' post in all the sections.
    For long serving members, this can be annoying, seeing the same post over and over again.
    What Peter was asking was for the 'multiple' posts to be deleted as they do not serve any extra function other than to annoy members.
    Careful, polite and respecful posts normally generate the most response.
    Also, new posters should remember that we all have daytime jobs so answers may take some time and are not always immediate.
    Jun 2006
    cambridgeshire
    31
    thanks frank and peter, do not mean to be rude BUT, you need to check who messages are from, scroll up and you will someone called davej joined the thread !!!! thanks for your advice on using the service though, i will try to be polite, respectfull and careful. and further, if more info is needed to answer my original request i would be more then happy to answer any questions ;-)
    Jun 2006
    cambridgeshire
    31
    AH RIGHT PETER, Sorry. 10'6 should have read 10foot 6 inches by ten foot 6 inches- inside measurements of conservatory. so could you go further with your calculations and try to give me a rating for unit needed PLEASE ;-)
    Oct 2001
    Nottingham UK
    5,667
    Quote Originally Posted by acgibo
    acgibo
    To determine the actual heat gain - and therefore matching cooling load you would need to provide precise details of the construction materials U values, glass ratio, glass type, roof construction, UK location, elevation, shading, blinds, colour, aspect, etc.
    Without this precise information we can only advise on a 'Rule of Thumb' calculation. Peter has proposed 125w/m2 whereas I would increase this to 200w/m2 to be confident of matching south facing, PVc construction conservatory heat gains. So for a floor area of 3.2 x 3.2m (10.24m2) x 200w/m2 you would need 2.048kw of cooling.
    Please remember that this is only a guide and a full calculation should be carried out before selecting suitable equipment.
    Jun 2006
    cambridgeshire
    31
    Smile Re: which unit do i need??
    cheers Frank, all those factors considered it looks like i would be better getting s.one in eh !!!!
    thanks a lot, i will check the forums regularly coz it looks very useful.
    take it easy
    Dave
    Oct 2001
    Nottingham UK
    5,667
    At least then you would have someone other than yourself to blame if it doesn't work
    Jun 2005
    Stoke on Trent
    588
    I work on m3 x 90 watts for my rule of thumb.
  1. Daikin a/c units.
    By rick in forum Air Conditioning
    Last Post: 18-02-2008, 09:22 PM
  2. Problem with ducted Daikin
    By jutty in forum Trouble Shooting
    Last Post: 23-07-2007, 05:34 AM
  3. M I T S U S H I T A ac unit with no condensing unit
    By Chinua in forum Air Conditioning
    Last Post: 28-07-2006, 06:54 PM
  4. Matching Evaporator with Condensing Unit
    By Abe in forum Technical Discussions
    Last Post: 25-07-2001, 08:57 AM
