Thread: Acid away
    May 2006
    Sydney
    12
    Acid away
    http://www.rectorseal.com/ac.htm#com...ted%20products
    Has anyone one used this?
    Does it work?
    Or should I steer clear?
    Thanks in advance
    11,024
    Re: Acid away
    I've used it in the past on small splits after a compressor change without problems; no guarantees though
    Nov 2005
    Southampton
    54
    Re: Acid away
    i've used it on small refrigeration systems , only because returing to site to change burnout driers and re-testing is uneconomical.
    don't forget to get the right one (POE type or Mineral Oil)
    The additive smells a lot like ammonia.
    Oct 2005
    nottingham UK
    109
    Re: Acid away
    Hi tiger, weve used it a fair bit, as aeb says saves changing burnout driers and weve ad no problems, although would check compressor manufacturer accept it, im not sure if maneurope accept it yet. well worth a try
    Feb 2006
    derbyshire
    610
    Re: Acid away
    alsobeen using it for years with no problems on all sorts of systems as a precaution, seems a sensible thing to do just in case there is a small amount of acid etc,
    May 2006
    Sydney
    12
    Re: Acid away
    Great feedback thanks all for that will give it a bash
    Feb 2001
    phoenix,arizona
    72
    103
    Re: Acid away
    For whatever this is worth. I use it for years...no problem.
    Be Happy
  1. Acid Test kits
    By techguy in forum Chit Chat & Service Stories
    Last Post: 08-12-2005, 03:10 PM
  2. Copper plating?????
    By ecclesk in forum Trouble Shooting
    Last Post: 04-11-2005, 10:35 AM
  3. removing acid from system
    By dantoubiana in forum Trouble Shooting
    Last Post: 08-03-2003, 10:48 PM
  4. R404a mineral oil ?
    By Richard in forum Refrigerants
    Last Post: 24-12-2002, 01:16 AM
  5. HCFC refrigerants, oils etc.
    By subzero*psia in forum Technical Discussions
    Last Post: 08-03-2001, 12:19 AM
