Thread: Choosing Evaporator
26-06-2006, 06:59 PM #1
Choosing Evaporator
I have a Copeland Condensing Unit
M9-LHA-50X-EWL
It has capacity 6.00 Kw at -30C
I wish to match it to an evaporator coil
Do I select an evaporator that has similar capacity?
ie: Something like a Friga Bohn
LUC 835C which is rated at 8.3Kw at -25c
or
LUC 645 which is rated at 5.1Kw at -25c
Which one would you select, the larger or smaller one? Bearing in mind I need to keep the cost down
Thank you
26-06-2006, 07:21 PM #2
Re: Choosing Evaporator
I dont have a catalogue in front of me but one Friga Bohn to avoid for low temperature use is the one that has a cowl that the fan sits in as water droplets form, freeze and jam the fan, doesn't matter what you try, you are never able to cure it.
What will the copeland do at -25c ?
What is the actual room temperature that you are looking for?
26-06-2006, 08:47 PM #3
Andy
The Copeland will do 3.6 Kw at evap -40C, 4.75Kw at evap -35 and 6.00 kw at evap -30C, and 7.45 Kw at -25C
I am looking for a room temp of around -18C
Im just trying to think of a Frigha I installed a couple of years back. Ive now replaced 4 fans already, the curved supports all snap off, Ill try take picture.
To replace they charge around 100 quid each.....these are just small 25 watt Mavib type fan motors, but designed around their design.
Has anyone tried to adapt, fit a normal fan motor into these coolers?
28-06-2006, 08:05 AM #4
abe, go searle,just had a price drop,reliable as they come,no icing up spots or cheap fans, you need a bit closer match but allways go slightly on the large side for a freezer [just my preferance] and order the heavey duty pan heater kit to be sure.
good luck.
28-06-2006, 09:09 AM #5
Hi, Abe
Originally Posted by Abe
Originally Posted by old gas bottle
Best regards,
Josip
28-06-2006, 09:31 AM #6
Hi, I am a newly jioned member to Refrigeration-engineer.
28-06-2006, 10:03 AM #7
Thank you Josip/ Old Gas Bottle
Designing Roll Bond Evaporator
By Munzar Ata in forum FundamentalsReplies: 11Last Post: 05-08-2010, 11:31 AM -
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
v bone evaporator trouble
By tranquanghvac in forum Trouble ShootingReplies: 0Last Post: 26-05-2006, 05:16 AM -
Change evaporator
By tralex in forum FundamentalsReplies: 6Last Post: 29-12-2005, 07:53 PM -
Iced Evaporator
By Abe in forum CommercialReplies: 13Last Post: 06-11-2002, 01:34 PM
