Thread: Hydraulic fittings
22-01-2022, 04:52 PM #1
Hydraulic fittings
What hydraulic fittings/adaptors have you found useful to have for working on industrial plant? For being able to connect a hose or a gauge, that sort of thing.
Come across 1/2" BSP 60º cone, 1/2" BSPP flat face, 6L compression, 6mm Swagelok, 1/4" 45º SAE flare.
23-01-2022, 04:52 PM #2
Re: Hydraulic fittings
Here in Norway we mainly use 1/2" BSPP flat face and 10L compression fittings, these are normal on Danfoss SNV valves. Most common on mycom compressors to have have 3/8 npt fitting for screwing in hose when de-pressurising units.
23-01-2022, 05:19 PM #3
Cheers HwT
