Thread: VRVII versus other
25-06-2006, 08:21 PM #1
VRVII versus other
I have to write an article about the VRVII from Daikin and make some comparisons between other brands. Total heat recovery.
What are the benefits of these new machines compared to the old ones.
I'm not familiar with Daikin, mainly due to their sale politics in Belgium.
What is the purpose of these boxes?
25-06-2006, 08:26 PM #2
Re: VRVII versus other
How are these units called? Ductable?
25-06-2006, 09:33 PM #3
Hi Peter
I've sent you a VRV brochure via e-mail, 5.2mb so it's too big to post here.
The Branch Selector Box (BS Box) is used on a 3 pipe heat recovery system. It contains solenoid valves that allow a connected fan coil to switch between heating or cooling. The inlet side to the box has Discharge gas, Liquid and Suction connections from the outdoor unit and the fan coil side has Liquid and Suction connections.
By switching the sol valves it can either send discharge gas to the fan coil and then feed liquid into the pipework system or take liquid and feed suction gas into the system.
On a 2 pipe system the BS box is not required as the whole system is either on heating or cooling - not both at the same time.
25-06-2006, 10:27 PM #4
Originally Posted by Peter_1Brian - Newton Abbot, Devon, UK
Gas powered vrv's versus absorbtion chillers
By eggs in forum Chit Chat & Service StoriesReplies: 7Last Post: 08-02-2006, 05:12 AM -
AKV versus TEV
By Peter_1 in forum Supermarket RefrigerationReplies: 15Last Post: 26-05-2004, 06:43 PM -
AKV versus higher load
By Peter_1 in forum IndustrialReplies: 20Last Post: 18-04-2004, 11:05 AM -
Chillers versus packs
By Peter_1 in forum Technical SpeculationsReplies: 15Last Post: 17-01-2004, 09:48 PM -
cheese versus aluminium?
By Friobernal in forum Technical SpeculationsReplies: 5Last Post: 01-03-2003, 08:18 PM
