    Nov 2014
    United Kingdom
    29
    1
    Mitsubishi City Multi Addressing.
    Hi guys,
    I have a job next week where I need to remove a wall mounted fan coil from a 4-5 year old city multi system ( don’t know exact model) and re commission system. Can anyone help explain how to re address the system once the fan coil has been removed would be much appreciated.
    Many thanks.
    11,025
    Re: Mitsubishi City Multi Addressing.
    Sorry I'm not up to date with these but maybe a manual might help....
    https://library.mitsubishielectric.c...ual__HWE1404A_
    Then search the manual for "address setting".
    Feb 2008
    505
    21
    if its heat recovery system you will need to no what port it is connected to on the box
    Feb 2008
    505
    21
    if you look at the rotary switches and set the new unit the same as the one you are removing
    Aug 2007
    Russia
    138
    21
    I would re address the system with the help of the dip named "Deletion of connection information."
