Thread: EVAPORATOR CHARGE ---> Questions
24-06-2006, 09:41 PM #1
Hello,
I know these are basic questions that a HVAC Technician probably shouldn't ask,
but, I'm getting a little confused.
- Why does a FROZEN EVAPORATOR indicate a LOW CHARGE? Shouldn't the refrigerent top-off at some saturated pressure and then build up sufficient SUPERHEAT to keep the coils from freezing?
- What are the symptoms of a FLOODED EVAPORATOR? Will that also freeze? Will the SUCTION LINE at the COMPRESSOR freeze-up?
Thanks!
24-06-2006, 10:49 PM #2
Re: EVAPORATOR CHARGE ---> Questions
1, A low charge allows the operating temperature to go below the norm for the system, hence frost and ice build up. As the ice builds up the transfer area decreases and the suction pressure gets lower and the ice builds up and so on.
It doesn't some much 'top-out' more 'bottom out'
2. The flooded evaporator may not freeze but you would suffer from frost etc on the suction at the compressor because the refrigerant is boiling it's way back to the compressor.Brian - Newton Abbot, Devon, UK
24-06-2006, 11:01 PM #3
Originally Posted by KETTLER
defective control,etc,etc.
A flooded evap will cause low superheat, delute the oil, break valves, and possibly destroy (scramble) the compressor. It will not freeze!
17-02-2007, 03:37 PM #4
17-02-2007, 04:00 PM #5
Cheerio Gary
Well said.
Ugh..... In the first place was he refering to
the plate freezers or walk in freezers .
Lets design a freezer that should not be open at all and seal air tight forever n does not serve its purpose.
Maybe no frost will develop on the tubing, no need defrosting mechanism and save everybody the trouble of maintenance
HEHEHEHEHE.......
14-03-2007, 11:55 PM #6
A sealed freezer ????
A scenario more for a quantum fridge engineer
perhaps schroedinger( ) could shed some light especially if you sealed his cat in there.
Interview questions
By zimbo in forum Chit Chat & Service StoriesReplies: 16Last Post: 10-09-2008, 10:06 PM -
few questions
By abbasi in forum FundamentalsReplies: 5Last Post: 16-07-2006, 11:28 AM -
some questions of air source hp
By Lc_shi in forum Technical DiscussionsReplies: 3Last Post: 11-05-2006, 08:58 PM -
questions
By parry in forum Chit Chat & Service StoriesReplies: 17Last Post: 31-10-2005, 09:46 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
