Results 1 to 9 of 9
    May 2006
    canada
    66
    R134A substitute ?? Help Pls.
    If a compressor is supposed to run on R134a, is there a substitute refrigerant that will run as well? I have been reading stories of capillary lines plugging, etc, and have realized that some of my problems are with the 134a as well.
    Apr 2006
    41
    1,620
    Re: R134A substitute ?? Help Pls.
    WTF? I am afraid that is impossible, unless you are using the wrong oil or the system has been horribly built.
    I can how ever tell you where you can get R-134a in Canada with out a ticket. For the system what you will have to do is ensure it is throughly cleaned inside then use a good quality POE oil and a good quality F/D (Filter/Dryer) If all thees things have been observed then you may have gotten a contaminated refrigerant.
    Jun 2006
    london
    10
    R507 but it will run the compressor hotter due to the increased pressure but it will also give you colder temps
    Jun 2001
    N.Ireland
    1,630
    Quote Originally Posted by northern-tech
    Any R12 drop in will work, the ester oil will not be a problem with these.
    R401a is the one I have used in the past
    Kind Regards Andy
    Oct 2001
    Nottingham UK
    5,668
    R134a is known for waxing the oil which in turn blocks capillaries. I prefer to use R49.
    May 2006
    canada
    66
    Thumbs up Re: R134A substitute ?? Help Pls.
    This R49.......is it available in North America, or is it under another name ??
    Thanks for the reply guys. Andy, I have used the
    R - 414B in the past, so may give this a try in the future.
    Jul 2006
    57
    R49 is R413a, it is a superb refrigerant.
    May 2006
    netherlands
    58
    I tried r409a as substitute for r134a in reciprocating compressor at -10 celcius evaporating temp. it still runs well.
    Feb 2008
    Georgia
    64
    I, too, have experienced many R134a units that have clogged the cap tube. I backflush evap and condensor with liquid R406A through my reclaimer to dissolve the clog and recharge with AB oil and R401A or R401B.
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. R12 to R134a
    By fireblade in forum Domestic
    Last Post: 19-08-2006, 09:02 PM
  3. Pressure Transmitter R134a Setpoints
    By cooltrain in forum Technical Speculations
    Last Post: 28-02-2005, 09:05 AM
  4. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
  5. Minimal required R134a speed in suction line
    By DaBit in forum CPU Overclockers
    Last Post: 08-05-2002, 05:19 AM
