    Oct 2003
    5,630
    4 pins connector on a Daikin compressor
    VRV II has 3 connectilns on its compressor ...U,V, W
    The replacement compressor has 4 connections: U, V, W and ...N
    N is connected in the starpoint of the compressor
    Why do they need an extrenal connection in the starpoint? Heating via pulsating DC current on 1 winding to heat up sump?
    Apr 2008
    Southampton, England
    49
    1,023
    Re: 4 pins connector on a Daikin compressor
    Someone told me it was to help measure compressor rpm, not sure it that's true...
    Not sure if it was for heating as only seen belt heaters on them.
    5,668
    It is a feedback signal to the electronics to indicate motor position
    Oct 2013
    Ukraine
    14
    IPM detects rotor position by reverse Elecro Mooving Forсe created by permanent magnets mooving near "empty" stator coil. Isn't it?
