Results 1 to 2 of 2
Thread: Leak Lock in compressor
19-10-2021, 08:39 PM #1
Hi, did the leak lock (small quantity) can damage AC swing compressor?
Someone give leak lock (not too much) into valves in outdoor unit AC.
We have a noise:
https://www.youtube.com/watch?v=IPq7s4UE5H4
In friday we want to open outdoor unit, maybe the compressor.
Anyone from you Guys had problem like that?
jest dobrze ale nie jest najgorzej
27-10-2021, 09:34 PM #2
Re: Leak Lock in compressor
It would account for the noise. Had a scroll years ago that pumped a bit of a shraeder depressor that sounded similar, luckily it quietened down after an hour and was ok.
Usually I just use some Nylog on flares, its like a grease so wouldn't do any harm if some got in the pipes etc.Mostly found in Oxfordshire, UK :)
