    Sep 2020
    Australia
    11
    GEA Grasso V series oil filter change
    Hi all,
    Hope you doing well.
    I have a Grasso V series compressor that needs an oil filter change.
    I noticed the oil level, in the sight glass, is higher than the oil filter.
    With that being the case do people normally drain the oil until its just below the filter level or will taking out the filter without draining oil result in A LOT of oil coming out?
    I was thinking of hooking a vacuum to the compressor and then removing the filter?
    3,356
    Re: GEA Grasso V series oil filter change
    No need, filter on discharge of oil pump.
    Expect 1-2 litres
    Nov 2009
    france
    64
    223
    Don't forget that there is also a suction oil filter inside. Fitted with a bayonet.
