    Sep 2021
    london
    3
    Carrier thermostat TAC662
    Hi everyone,
    my thermostat TAC662 is faulty (display turns on but pressing any button des nothing) and I need to replace it but it seems this is an old model and I am struggling to find a replacement. Do you know of any compatible thermostat in the market?
    As my thermostat has the typical 4 wires (color coded, red,black,green and yellow), would it be enough to just reconnect those wires to the new thermostat?
    Carrier Model: CIMA PLUS 100B (INTERNAL UNIT 40AVR034T)
    many thanks
    ireland
    1,450
    Re: Carrier thermostat TAC662
    Have you w1/y1 terminals and 24v supply? If so any stat will be compatible, home depot have a good range.
    Sep 2021
    london
    3
    y1=cool
    g1=fan
    b1=heat
    r1=12v
    is it right?
    thanks!!
    5,667
    No. Red + Black are power. Yellow + Green are data communications
    Sep 2021
    london
    3
    so no way of replacing it with a "compatible" one? the only solution is to go to Carrier and buy the same model?
    All the thermostats I see to buy online (and DIY videos in Youtube) have another way for wiring: i.e. yellow=cooling, green=fan,red=power, white=heating... and all of them follow the same pattern. So Carrier making the things easier :-D
    many thanks
    5,667
    Search Google for the manual and you will see the wiring.
    All of the carrier unit's I've come across have data comms on the controllers
Tags for this Thread
