Thread: Carrier thermostat TAC662
Hybrid View
21-09-2021, 11:25 AM #1
Hi everyone,
my thermostat TAC662 is faulty (display turns on but pressing any button des nothing) and I need to replace it but it seems this is an old model and I am struggling to find a replacement. Do you know of any compatible thermostat in the market?
As my thermostat has the typical 4 wires (color coded, red,black,green and yellow), would it be enough to just reconnect those wires to the new thermostat?
Carrier Model: CIMA PLUS 100B (INTERNAL UNIT 40AVR034T)
many thanks
21-09-2021, 07:52 PM #2
Re: Carrier thermostat TAC662
Have you w1/y1 terminals and 24v supply? If so any stat will be compatible, home depot have a good range.
24-09-2021, 08:38 AM #3
y1=cool
g1=fan
b1=heat
r1=12v
is it right?
thanks!!
tac662 reduced.jpgLast edited by pollapiton; 24-09-2021 at 08:43 AM.
24-09-2021, 02:26 PM #4
No. Red + Black are power. Yellow + Green are data communications
25-09-2021, 11:08 AM #5
so no way of replacing it with a "compatible" one? the only solution is to go to Carrier and buy the same model?
All the thermostats I see to buy online (and DIY videos in Youtube) have another way for wiring: i.e. yellow=cooling, green=fan,red=power, white=heating... and all of them follow the same pattern. So Carrier making the things easier :-D
many thanks
25-09-2021, 07:20 PM #6
Search Google for the manual and you will see the wiring.
All of the carrier unit's I've come across have data comms on the controllers
