    Aug 2021
    1
    Quantum HD Slide Valve not responding
    We are running a frick Screw off of Quantum HD panel. The slide valve will not respond (load or Unload). It will not respond from manual, auto, or remote attempts. I've checked output fuses and they are good. To me it seams to be a configuration/communications issue that I cant track down. Any Advise?
    Sep 2009
    Iran
    66
    672
    1
    Re: Quantum HD Slide Valve not responding
    Check the solenoid valves.
    And all valves
    Also oil pressure
    3,355
    cookieman,
    What Frick model compressor do you have, like TDSH,SGC,XJS etc.
    There are a few differences with potentiometers.
    Like mbc suggests, can you determine if load, or unloading solenoid is getting energized.
    Jul 2006
    74
    865
    26
    Does the Solenoid have the capability to be operated manually by depressing the ends?
Tags for this Thread
