Thread: TK error code. Help me...
31-12-2010, 09:03 PM #1
Getting an error code of 63 on my reefer. Can someone help me reset the unit? Please let me know what info you need from me to help you help me. The engine would not start due to cold weather and the switch was left on. Now the error code is not allowing the unit to start. Any help is very appreciated. That error code is listed on the door and simply says engine not starting for unknown reason.
01-01-2011, 02:48 PM #2
01-01-2011, 08:02 PM #3
01-01-2011, 09:14 PM #4
Re: TK error code. Help me...
Check you have fuel to injection pump is elec pump working if not tap it and sea if it bursts into life check supply to pump with recent ambients we have had freezing fuel split pipes and jammed sol valve also on older kit make sure fuel pipes not kinked firstly sea if elec pump clicking and fuel to injec pump be lucky
02-01-2011, 11:06 AM #5
It would help if we knew what kind of unit it is (truck or trailer) and which controller (TGVI or SR). A photo would be nice.
Cheers,
Rob
