    Jan 2021
    NZ
    4
    Daikin WiFi adpter can't access it from outside home
    Hi All
    I have got Daikin 6KW Model FTXF60TVMA split system with WiFi Adapter model BRP072C42
    I managed to connect WiFi to my home router means I can use app on my iPhone to access the adapter hence I can turn on and off Daikin
    The app has a section where you can access your air condition when you are outside home means using internet and to do so the app asks you to create a credential (username and password),,,,so far I created 5 (FIVE) usernames and 5 password and when I tried to login it says :
    Thx
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin WiFi adpter can't access it from outside home
    zillah
    You need to enable 'out of house' when at home by opening the app and then selecting the indoor unit.
    Once selected, press the gearwheel top of right, and move the slider to ON. Next, enter a log in code of your choice and a password at least 8 characters long. Save.
    Now, when you are away from home, open the app and log in. Simples.
    Jan 2021
    NZ
    4
    Thx frank
    issue fixed
