    Jul 2001
    hong kong
    65
    27
    measuring vacuum unit
    please advise how to identify between the unit "micron" and "torr", how to convert them?
    thank you
    vB Code is ON
    St. Louis, MO
    509
    A 'torr' is the pressure exerted by a 1 mm column of mercury. The Prof hasn't seen the term 'torr' used much... 'mm Hg' seems more common. A 'micron' is the pressure exerted by a 1 micron (one millionth of a meter) column of mercury.
    Since there are exactly 1000 microns to the millimeter, the conversion from torr to microns is easy to remember:
    1 torr = 1000 microns
    Relating these units to atmosphere:
    1 atm = 760 mm Hg (torr)
    1 atm = 760,000 microns
    Prof Sporlan
    Georgia, USA
    58
    Hey Prof,
    Frequently I run across converting inches hg to psia and vice versa, have you any handy formulas for this.
    I use one for inches hg to psia = subtract inches hg from 29.9
    divide result by 2.04 to get PSIA.
    Mike Hopkins
    nadeem majeed's Avatar
    nadeem majeed Guest
    Re: measuring vacuum unit
    when we vacuum the a/c unit maximum it goes to -1 bar can we get the vacuum more than -1 bar on same atmospheric pressure
    Split Croatia
    6,151
    Quote Originally Posted by nadeem majeed View Post
    You cant go below-1 bar on any atmospheric pressure. That is absolute vacuum!
    But because of inaccurate gauge, you may see lower pressure!
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    Quote Originally Posted by watana View Post
    thank you
    buy 1 of these mate.
    http://www.toolstop.co.uk/cps-vg200-...um-gauge-p1327
    Oct 2003
    5,630
    Nadeem, don't make twice the same post in a different section.
    Therefore I will close this one and suggest you go to http://www.refrigeration-engineer.co...283#post125283
  1. Daikin a/c units.
    By rick in forum Air Conditioning
    Last Post: 18-02-2008, 09:22 PM
  2. Problem with ducted Daikin
    By jutty in forum Trouble Shooting
    Last Post: 23-07-2007, 05:34 AM
  3. M I T S U S H I T A ac unit with no condensing unit
    By Chinua in forum Air Conditioning
    Last Post: 28-07-2006, 06:54 PM
  4. York/Bristol Condensing Unit
    By Abe in forum Commercial
    Last Post: 03-02-2003, 07:46 PM
