Thread: measuring vacuum unit
30-12-2001, 04:25 PM #1
please advise how to identify between the unit "micron" and "torr", how to convert them?
thank you
vB Code is ON
31-12-2001, 03:48 PM #2
A 'torr' is the pressure exerted by a 1 mm column of mercury. The Prof hasn't seen the term 'torr' used much... 'mm Hg' seems more common. A 'micron' is the pressure exerted by a 1 micron (one millionth of a meter) column of mercury.
Since there are exactly 1000 microns to the millimeter, the conversion from torr to microns is easy to remember:
1 torr = 1000 microns
Relating these units to atmosphere:
1 atm = 760 mm Hg (torr)
1 atm = 760,000 micronsProf Sporlan
14-01-2002, 01:56 AM #3
Hey Prof,
Frequently I run across converting inches hg to psia and vice versa, have you any handy formulas for this.
I use one for inches hg to psia = subtract inches hg from 29.9
divide result by 2.04 to get PSIA.
Mike Hopkins
07-11-2008, 12:32 PM #4
Re: measuring vacuum unit
when we vacuum the a/c unit maximum it goes to -1 bar can we get the vacuum more than -1 bar on same atmospheric pressure
08-11-2008, 10:08 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
09-11-2008, 08:05 AM #6
buy 1 of these mate.
http://www.toolstop.co.uk/cps-vg200-...um-gauge-p1327
09-11-2008, 08:55 AM #7
Nadeem, don't make twice the same post in a different section.
Therefore I will close this one and suggest you go to http://www.refrigeration-engineer.co...283#post125283It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Daikin a/c units.
By rick in forum Air ConditioningReplies: 59Last Post: 18-02-2008, 09:22 PM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
M I T S U S H I T A ac unit with no condensing unit
By Chinua in forum Air ConditioningReplies: 2Last Post: 28-07-2006, 06:54 PM -
York/Bristol Condensing Unit
By Abe in forum CommercialReplies: 1Last Post: 03-02-2003, 07:46 PM
