    Jul 2021
    Singapore
    2
    Lowering maximum temperature
    I got a freezer that can go to maximum -15 degrees now.
    Would it be able to go to -20 degrees if I change the thermostat max settings?
    Sep 2009
    Iran
    66
    672
    1
    Re: Lowering maximum temperature
    Main thing is that .
    But to give you right answer need to know more about your system
    Type of refrigerant and compressor.
    May 2012
    59
    1,528
    36
    Minus 15 for a freezer is unusual.
    Minus 20 is more like the normal.
    Are you sure this is a freezer?
    Rob
    11,025
    Did it go to lower temperatures before now?
    What is ambient temperature around the freezer?
    Has anything changed since first installation?
    Is compressor running still at -15 or is thermostat still calling for compressor?
    Jul 2021
    Singapore
    2
    No, it did not go below -15.
    Compressor model: L76CZ1
    Refrigerant: R134A
    Understand that R134A is not able to go to lower temperature. Must be R404A, correct?
    May 2012
    59
    1,528
    36
    If it is this comp then Minus 23 evap temp equates to about minus 13 case temp.
    https://www.womacool.com/productinfo/284992.html
    So if it is at minus 15 then you are at the limits of the comp.
    Rob
    Aug 2021
    Scotland
    14
    On 134a comp would need to run in vac on suction to achieve -20, which is never a good idea unless it is a special design, for low temp should be 448A, 449A, 407A or F, but on a 134a system may well require different pipework sizing, would probably be better to replace with a properly specified system.
