    Jun 2021
    Australia victoria australia
    2
    Lightbulb wanna learn about glycol I have been working Refrigeration for 10
    first post
    hanks in advace for your time replying
    Hello guys nathan here from victoria ,
    I'm working on a new project I would like to know how to build a 6 tap beer system what size condensing unit do I use what gas I was thinking r404a how my glycol do I need how much Cooper do I put in the evap i was thinking of putting 10 meters of copper in the evap is that enough I was think of getting com wire mesh and winding in round in a circle and dropping it a 100 l plastic feed drum and make a box and fill it up with expanding foam . what to would u expect what cut out temp would u expect and what sub cooling and super heat would U. run still 5 to 7 K. and suction and discharge pressure this is a hight use application how much time it will time to build a ice bank
    • questions
    • glycol %
    • suction pressure
    • DISCHARGE pressure
    • sub cooling
    • what super heat
    • how much copper to use
    • what oriface
    • what size pipe size
    • and how meny kw it would be
    • every one wants a ice cold beer
    thanks in advace for your time replying
    3,355
    Re: wanna learn about glycol I have been working Refrigeration for 10
    Nathan,
    Hope someone here can help you out.
    A few questions
    What’t it for, personal use, football club or something like that?
    How much money in Budget?
    How many different types of beer?
    How much beer would you expect to use each day or night.
    Have you worked out cost saving if keg against cans, or stubbies?
    I’m initially thinking just a cool room & fridge for keg or cans or stubbies, seems simpler.
    What do you think?
    3,355
    Some links might help, more work with kegs, got to clean lines regularly, or beer taste no good, Co2 required, cooling lines to taps if you want cold beer every pull.
    https://www.kegworks.com/draft-beer/...oling-systems/
    https://www.andale.com.au/glycol-beer-system/
    Jun 2021
    2
    Thanks for ya help that web link has helped a lot
    Sep 2009
    Iran
    66
    672
    1
    hi
    I had worked in Auckland ( Faces bars and sky tower )
    in both we had drums on Cold Rooms and one glycol tanks with small pump to circulate glycol .
    in this system you could served a lot of taps.
    and control temperature of them is a easy .
    make a sure stainless steel tanks is big and all beers and glycol pipe have a good insulate .
Tags for this Thread
