Thread: Daikin service checker help
26-04-2021, 12:07 PM #1
Hi All
Your help would be greatly appreciated.
Does anyone know if a Daikin Service Checker Type 3 is still usable on recent systems, the one that I have been offered only as version 1.09 software.
Does anyone know of/have a newer version of software
Also as anyone used a USB Parallel port converter to connect
Many thanks
Dave
26-04-2021, 07:09 PM #2
Re: Daikin service checker help
Hello Dave
The service checker is a tool only. Service checker software is what you install onto your laptop. Latest version software is available from Daikin or online. Latest version I used was 1.55b. Some of the later versions include being able to connect to Altherma etc.Last edited by frank; 27-04-2021 at 09:58 AM. Reason: Typo
27-04-2021, 08:24 AM #3
Hi Frank
Many thanks for replying.
Can I ask you about the PC that you use, as I see that the checker needs a parallel port. My laptop doesn’t have one, so was wondering if an external one would work, or do I need to find an old laptop.
Dave
27-04-2021, 09:57 AM #4
I used a Parallel to USB converter then plugged into a USB port. I've used it on both Win XP and Win 7.
https://www.lindy.co.uk/usb-c4/usb-c...converter-p485
Not sure about Win 10 as I've had no need to upgrade. Quite happy with Win 7.
I've had to select the correct USB port in the settings as I've found that Daikin software is not that clever in detecting the USB port.
Just had a look and Daikin are doing an online training session for Service Checker early May 2021
https://daikintraining.co.uk/trainin...er_by=date_ascLast edited by frank; 27-04-2021 at 10:07 AM. Reason: More info added
27-04-2021, 11:54 AM #5
Thanks for that, I’ve ordered a cable and usb floppy to install software.
Now have software ver 1.66
Didn’t realise that Daikin had online courses, so checked, but all full. Will keep looking
Once again thanks for your time
