Page 1 of 2 12 LastLast
Results 1 to 50 of 78
    Apr 2021
    Australia
    48
    Fujitsu ASTA24LCC domestic A/C removing drain hose
    I'm new here as a found some ggle links that suggest I may find some knowledgeable's that may provide me with some assistance. I have searched; YT + ggle + fixya +......++++. I have been at this for days and I'm at my wits end to find a (any/reliable) solution.
    The (indoor) AC is as noted. The fan/blower motor bearings are knacked and I wish to remove the motor and replace the bearings (yep can be done) - new motor ~$200 (& $450+ labour), new bearings ~ $20-30. Plus the motor is a squirrel cage (induction mtr), very electrically robust, so re-using no probs.
    The mtr lives in the drain pan assembly and with an easy strip down (which I have done) the drain pan separates from the condenser assembly (drops down). Problem being is that the d/pan drain hose going through wall to outside is stopping dropping the d/pan completely. LH side can separate from condenser head but RH side caught due to d/hose. Does anyone know how to remove this hose, please oh please? Apparently it is fixed to the pan with a screw (may also be glued?) but only having < 50mm between the wall and pan hose entry, cannot see + also can't get any tool in there to remove if there us a screw. The hose is flexible (it seems) and has a (insul) covering. Can this hose be cut further down and re-joined (if have to)? Would very much appreciate assistance with removing this hose, once done everything else pretty easy stuff...Thank you
    Re: Fujitsu ASTA24LCC domestic A/C removing drain hose
    Those hoses are genrally a push fit, albeit a hard push, try a flat blade as a twisting lever at the top of the hose where it fits the drain pan.
    May 2012
    59
    1,528
    From experience I have only ever known these to be a push fit and if you look up the parts list you
    can see the drain with the push fit ends.
    I don't think this model should be any different so as Brian says the drain hole fitting is fixed to the
    tray and the drain should be a push fit over that (but there is always a first time).
    What you call the condenser assemble is the evaporator (the condenser is outside) the drain tray
    is flimsy if you are rough with it but if you can hold the pipe with grips and slowly pull and twist the
    tray it should come free.
    Rob
    May 2012
    59
    1,528
    Ps if you are capable of removing all the components and replacing the bearings
    why not just replace the whole motor assemble yourself and have done with it?
    You won't incur any labour costs that way.
    But be warned one way for AC engineers to make money is to follow people who think
    they can do the job cheaper themselves.
    It is not the dearest option to get a professional to do it right first time, plus you have warranty.
    Rob
    Apr 2021
    Australia
    48
    Hi Brian, thank you for your reply. Indeed sir, oh, I just wish it were as you described, I would have had it all done and dusted, 10.3 days ago. Yes, I've been trying to get info and advise for this period. I can't find install/service manual, unless I sign up for "free" with c/card-no trust in this.
    I can find some Fujitsu docs which have wall mounted units (not this one) which advise hose is attached with what appears to be a saddle(?) clamp and screw. Screw is not side mounted but goes straight in, same direction as hose. This is also backed up, by, there is no cut-out at the side to get to screw as installer would have used this to attach. Have also chanced upon some discussion where others mention pushed on and glued. Also in text others mention steps to take off d/pan, saying "remove drain hose" as one of the steps but don't tell you how. So if I go in there and heave on it I will stuff up the hose. Getting another hose back on will be another pain. So I'm trying to get as much correct info as I can so as to not cause more issues.
    The d/pan is encased in polystyrene and the d/hose enters a hole in this and goes all the way to the plastic case inside (depth ~ 45mm)...so you can't get to it, can't see how it attaches (inspect mirror/lamp-no go), no levering with s/driver etc. Photos are attached.
    AC shop, I got out initially, thinking their "service" would separate this d/pan to clean (yeah, office "Susan" said they would-but nah) only removed outside cover, fluffed around (temp/current check), charged me $140. I called later concerning d/pan, d/hose removal + mtr ~ $650. Asked how to - for d/hose removal, advised most are glued so they cut further back as hose goes out through wall to connect to solid drain tube (exits outside to ground), then re-join. So if no others can assist this may have to be the way. However the visiting AC dude did not seem too cluey so I'm cautious. However appears to be the only option or pay.
    Anyone have an install/service manual for this ASTA24LCC it would be gratefully appreciated + still seeking knowledgeable advise. I'm not in a financial position to afford the shops cost + I've stripped it to the stage where once d/hose off I can complete and re-assemble. Thank you
    Apr 2021
    Australia
    48
    Thank you Rob...I respectfully hear your words and value what you have stated (thanks for correction on h/ware terminology). And I may have to look at the the AC Eng option. However, I'm out of work (E/Eng) at this point, so $'s tight but heaps of time + have taken on issues above this with no probs. All that is stopping me is a damn hose/lack of info. Reason for mtr repair (and not complete swap) is as noted from experience/knowledge, squirrel cage mtrs, rarely electrically fail. Bearings always eventually fail, easy to replace and cost effective ($20-30) compared to $200 for a new one (+ 20days wait to get). I also like to re-use where possible and not waste resources. Thank you for you tips on hose removal, I may chance it...? Many thanks Rob
    May 2012
    59
    1,528
    Try this.
    http://spares.bigwarehouse.com.au/pr...cts_id=1679399
    https://www.manualslib.com/products/...c-2783246.html
    It shows the hose as a separate item with the flexible push fit ends.
    Rob
    May 2012
    59
    1,528
    Quote Originally Posted by Tigercat View Post
    Oh and that must be the politest rebuttal in internet history.
    I like you.
    The drawing I linked is slightly different in model but it give you an idea of what the drain looks like.
    Rob
    May 2012
    59
    1,528
    Try this exploded diagram.
    http://spares.bigwarehouse.com.au/im...51e5240c7b.pdf
    Rob
    5,667
    If you look on page 14, item 50, you can see a small endplate with a hole in it. If your hose does not have one of these then it is just a push fit. https://guidessimo.com/document/3212...manual-22.html
    To replace the fan scroll, which I think is your original enquiry, then you are going to have to remove the drain pan assembly, the electrical pcb housing, the fan motor AND lift up the evaporator coil to gain access. This is quite a tricky process which, not only leads to "coil rash" (cuts to your skin from the fins), but can lead to fracturing the pipes. Not really a job for the untrained. Doesn't mean that it can't be done but be aware of the pitfalls.
    If you decide to tackle this yourself, then good luck, and don't hesitate to drop back if you get stuck.
    Tigercat, having looked at some installation details I can see your problem with needing to access that screw holding the drain hose in place.
    Knowing that you have knowledge and tools my next question is - are you up to drilling a new hole in the wall to run a new drain hose?
    My suggestiton is this:-
    1. Cut the existing drain hose as far from the drain pan as possible.
    2. Remove the drain pan from the unit and unscrew the existing drain locking ring.
    3. Remove the blanking plug from the other end of the drain pan so that you can fit the repositioned drain hose.
    4. Fit the blanking plug in the old drain hole.
    5. Make a new hole in the wall to accept your new drain pipe.
    6. Make up a new drain pipe to connect with the old existing part that you removed/cut off.
    7. Fit the modified drain pipe to the drain pan.
    8. Refit drain pan and test run some water through the pan.
    9. Have a well desreved coffee or something stronger.
    Apr 2021
    Australia
    48
    Hahaha good onya mate; dear Rob, I've taken a shine to you as well. Nah, mate, that's no rebuttal. Just a sincere and genuine statement to say thank you for your advise and I'm in thought mode with what you and Brian have suggested. You and Brian are experienced in this area...me = 0, so I'm definitely in the listen up mode.
    However my thought process is: 1)I heave on the hose and stuff it=more issues to fix it+new hose, Engineer heaves on it, stuffs it, extra labour+ exorbitant cost new hose + hose still has to be removed (cut and re-joined on outside wall) to re-join. 2)I heave and it comes off-yippee=$0, Eng heaves on it-still=$+450 labour charge. 3) I decide to cut hose (further along) where it routes along the outer wall, pull through wall, then re-join after-none of the above will occur, Engineer rocks up and says, yep I need to cut and re-join (as the advise given, via your ph call to us-which I was not overly trusting but options are limited), again still=$+450.
    So, 3) has (appears??) the lowest risk for both. Hose is accessible on outside wall and is easily doable + need to (remember haha) tie cord around severed end to pull back through wall when pan re-installed
    If hose is cut on outside wall (~400mm from where it attaches to d/pan) and pulled through the opening in the wall it will resemble the image in the manual you supplied, pan should then come off. I also found and browsed manualslib but the operator manuals do not show how hose is attached to pan...service manual (not available there/anywhere) would do the trick...found one prior for a Fujitsu (similar arrangement as mine?)
    http://www.fujitsuklime.com/wf-doc/f...ion-manual.pdf
    Page EN-4, shows how this model attaches drain. And even in this case, how to get to the fastener when unit is <50mm from the wall? No special tooling is noted to achieve this. Still looks like a cut and join unfortunately? I do hate cutting stuff though, always like to avoid.
    Hey Rob it's great to be liked, haha, and I think I understand your sense of humour. Great to have a banter with you sir...Tigercat
    Apr 2021
    Australia
    48
    Hey thanks Brian. Yeah mate it is a PITFA. Yeah mate, I have a feeling it has this locking ring arrangement + funnelled down inside a 45mm styrene cavity until it meets the attachment point on d/pan. You are also where I 'm at. From the pics I sent the drain hose is visible going through wall to the d/pan. I was going to cut/remove unit drain hose (as supplied d/hose is not overly long) where it meets up with pvc (to drain to outside) on the other side of this wall (access no probs). Tie a length of cord around this end, then go inside and pull this hose through (with cord attached) the wall hole. It's a double brick wall, so approx 20cm distance from inside to outside wall + hole is large with space to maneuver hose through. Hopefully fix mtr issue, attach hose to d/pan and pull hose, via cord back through hole, refit d/pan. Haha, theory is always a tease though...
    I very much appreciate your detailed, informative suggestions Brian. I could not go wrong in following what you have outlined...thank you
    Apr 2021
    Australia
    48
    Thank you Frank for the info. I can't see up inside where the hose attaches to the d/pan, it's buried in 45mm of polystyrene <50mm away from a wall. I sent Brian_UK (my first reply, so top of thread) x3 pics which show the situation. Yeah mate AC is all stripped down as you have outlined. Removing d/hose and all should be good to go....haha, and that sir, is where I'm caught and yes I'm a bit hesitant; I'm sure I can fracture pipes better than most ...very much appreciate your input and guidance, your points are noted, as I am very much untrained...Thank you
    5,667
    What you will find is that the plastic drain pipe which is moulded as part of the drain pan, travels through the polystyrene so that the drain hose can push onto it. The drain hose doesnt extend into the polysyrene.
    Have a close look at the other end of the drain pan that currently has the stopper in it and you should see what I mean.
    The drain pan is moulded this way so you can choose which end to attach the drain hose to suit your installation.
    You can remove the drain pan with the hose attached so that it swings down out of the way but in my experience it is best to remove it to change the fan rotor.
    I'm not sure that the drain hose is going to be your biggest problem on this project.
    Apr 2021
    Australia
    48
    Yeah, sorry Frank I did not choose my wordage correctly. Post #13 (to Brian_UK) explains better. Yes, the hose does enters into the cavity moulded into the p/styrene d/pan "shroud" and goes to spout on d/pan (can't see it but assume this is the way). And yes sir either end of d/pan can be used for drain purpose, I did note the LH side option. Indeed I thought the d/pan would swing out with the hose attached as you have suggested...but alas it did not.
    Haha, that's why I'm chatting to all you nice folks because the brstd didn't/wouldn't do this, swing down. All the attachment points have been removed and the d/pan needs a gentle pull down to separate it from the evaporator (thanks Rob), from what I have gained from discussions on web (but no instructions given though-haha), just general chit-chat saved on forum boards from a few years back.
    Sounds like you have had experience with this situation Frank?
    Frank, I'm pretty sure you're spot on mate! It also may not be my biggest problem. Thank you Frank. I'm going to wait for a wee while and gauge all my options before any attempt(s)
    5,667
    What is on the other side of the wall where the drain pipe exits? Can this be disconnected to allow the original flex hose to be pulled back?
    When we install these units, the lower half of the unit is pulled away from the wall on it's bracket to allow us to make the pipework connection. Seems strange that yours is only 50mm from the wall with no 'play' to allow access to the joints
    Apr 2021
    Australia
    48
    Hi Frank, yes indeed, that was what I had in mind. Yeah, I just don't think I had the guts to push areas around even though I have read (discussions) noting that the evaporator should move up a bit on it's mountings, allowing lower half to "drop down". I'm wanting to approach with the low risk mode if possible, I can fracture piping better than most I'm sure, haha.
    Below is what I noted to Brian in post #13, concerning what I had in mind...Thank you Frank, I appreciate your knowledge and info, we all closing in on the same "page".
    Apr 2008
    Southampton, England
    49
    1,023
    Hi fruity.
    I've emailed a few manuals to the address on your vcard. There's the install, service and technical manual and also a file for getting access to the motor on newer units which might be of interest although it looks you are pretty much there anyway.
    They are from my company email and might go to the junk folder so check there if nothing turns up.
    From what I recall I'm fairly certain it is a push fit donkey dik (correct terminology!) on those units. If you can get a mirror on the spigot on the left hand side to confirm there is/isn't a hole to screw it in should confirm.
    If so it could well be the rubber/plastic has stuck together and best way is to twist it free although I can see that is easier said than done.
    Cheers,
    Andy.
    Edit: correct terminology falling foul of the language filter but you get my jist.
    Apr 2021
    Australia
    48
    Hello there Andy,
    Thank you very much sir for the manuals (wow), very much appreciated. I have received them (x5 files) and will have a lookie. I'm hoping this ASYA model info has the same set-up as my ASTA(?). And also thank you Andy for your own info RE: hose fit. A massive help and a lot of effort from your side.
    Yes from what I found here;
    Not my model but similar, maybe...?
    It indicates a screw access hole (on LH side as you suggested) combined with the styrene tunnel that accepts the d/hose. I cannot see this on the LH side (of my AC) but I can (I think) see an extra access port on the top (not side) of the styrene tunnel...will investigate further.
    I will report back to this thread on what I find/where I'm at (have not tackled that pesky hose yet) ...as I'm still mulling over options and going through the fantastic response/info that all have supplied....
    Many thanks Andy
    Apr 2021
    Australia
    48
    Howdy all....ah, some progress. Got back to having some more play to drop that damn drain pan before moving onto the drain hose. And I now have the complete d/pan dropped to where I can get to the screws (hopefully??).
    Photos attached...
    Previously, the LH side dropped no probs (basically without any force at all). Applied the same technique to the RH side but it seemed snagged, did not want to force it. So hopped onto this forum to see what others could provide to assist. A big thank you to all for engaging with me, as I'm new here and posses none of the following; knowledge, experience and information, however you guys do and provided much need assistance, guidance.
    Ok. so here is the go to ----> I re-seated the d/pan to it's original level position ie. d/pan re-engaged to the evaporator (LH and RH side flush and level set under the evap) all fasteners still removed. Instead of having a go at the LH side then trying to move the RH side. I gave a gentle firm pull/wiggle (first) to the RH side and down it came, the hose allowed itself to bend down with the pan....yippeee. The LH side then became a bit of a brstd and needed some extra pull/wriggle but at least the d/hose is not there, therefore not the reason for snagging.
    Now just have to maneuver screwdriver(s) to get the mtr holding screws out and then mtr should be free. Will take more snaps when mtr out and dismantled....Thank you once again
    5,667
    Well done so far......
    To remove the motor/fan rotor, you will need to split the motor from the rotor.
    If you look carefully into the rotor middle at the motor end, you will see the head of an Allen key or screw. The rotor design is cast to allow you to introduce a tool to loosen this. This is how the rotor is attached to the motor shaft. Once loosened, not removed, you can remove the motor by sliding it out to the right, leaving the rotor in place.
    These rotors are 'balanced' to prevent vibration, and are easily knocked out of balance by either chipping bits off while removing or not cleaning them fully. Due to the cost of the replacement part and from experience many times of stripping, cleaning and re-building these units during routine servicing, only to find that they then vibrate, I used to always install a new rotor assembly if there was a need to strip them down. Saves no end of time and heartache.
    The opposite end of the rotor to the motor end has a small shaft that locates into a small bearing that is located into a rubber bush mounting. This was also always replaced.
  23. #23
    Apr 2021
    Australia
    48
    Thanks Frank, no worries mate. Once I dropped the pan, Mr Newton assisted me with swinging the pan to the RH side and the whole pan came away (yes disengaged the hose as well). So yep, the hose was a push on (as others of knowledge have suggested). AC dudes advised it would be glued, many doc's showed it fixing with a fastener. So difficult to access and proceed.....
    This hose and how it was attached was what was causing me all the issues...now I know how it goes, I'm pretty much sorted to re-furbish.
    Yeah Frank, I did dis-assembled before I got your instructions, however, took great care with the blower scroll and the end bushing, have had experience with all this type of stuff before. I can see where they have added "weight" crimps (for balancing)to the scroll fan + it has some crude build up.
    I note your tips RE: replace scroll/rotor + rubber mounted bushing and thank you. I'm in scrooge mode, so I'm going to v.carefully wash/clean scroll and re-use end bushing ($25 + 14+ days delivery/new)---I will re-grease end bushing with silicone grease. I can understand AC Eng replacing these though. But for me now knowing what I'm in for I will try re-using, as now taking apart AC is easy. If I run into probs can get back into it ok. Will get into splitting the mtr, swap out the bearings and all should be sweet. Thank you Frank for your valuable knowledge. I will post some more pics as I progress, hopefully may help others.
  24. #24
    Apr 2021
    Australia
    48
    OK - for those that may have an interest. Drain pan removed as per my last previous post. I have stripped it down, making sure that electronics (tether to frame with a tie) is not left dangling via it's conductors. Cover with a protector, preferably an anti static bag.
    I've cleaned all the covers with a very mild detergent solution and used a directional garden hose sprayer to flush off/clean. BE VERY careful with the d.pan and keep e'tronics upright in a bag out of the way. I could not remove e'tronics due to hassle removing stepper mtr couplings. Using directional g/hose sprayer hopefully (+others as per photo) stops parts other than the pan itself from being flushed/spayed. Also X2 pivot points for the louver system were seized, stopping swing from operating correctly - used silicone spray to release, after d/pan dry, lubed all these pivot points with this spray.
    The scroll/blower fan was a chore as it was covered in tiny (<1mm) flies (hundreds of them), stuck on big time. Put this in my bath + water/deter with a thick towel under it to stop any damage when moving it around. I used a very mild detergent + paint brush + a gentle blast from the g/hose (after bath)evap_minus_d.pan01[1].jpgd.pan01a[1].jpgd.pan02a[1].jpgd.hose_exit01[1].jpgcleaning_d.pan01[1].jpg to get those brstd's off. Installer did not seal hole in wall that's how they got in.
    Fan/blower mtr is out (pic). Just above the Panasonic sticker a divot/gap is seen, there are x3 of them around mtr housing. This is where a "punch" of sorts (s/driver) can be placed. Bore a hole in a piece of wood to accept and support motor spindle, insert spindle and tap punch at divots with hammer and the cover should come away. Will post more once I get this mtr cover off (haha, hopefully).
  25. #25
    Apr 2021
    Australia
    48
    Photos continued....blowerfan+end_bush[1].jpgfan;blowermtr01[1].jpgfan;blowermtr02[1].jpgblowerfan_cleaned01[1].jpglouver_steppermtr's01[1].jpg
    And Frank's suggestion to replace with a new end bush is a damn good idea (thank you Frank) even though I was going to reuse the old one...new one makes good sense, even having to wait to get it.
    Forum brd s/ware only allows x5 photos/post, so more photos in next post.
  26. #26
    Apr 2021
    Australia
    48
    Fan/blower mtr removed. Cutout/divots in mtr housing noted above Panasonic sticker. Can tap with "punch" (x3 around circumference) and remove the aluminium coloured mtr cap....yep, there will be a circuit brd under this + top bearing. Will post more when into mtrfan;blowermtr01[1].jpgfan;blowermtr02[1].jpg
  27. #27
    Now you know why we servicee technicians always looked forward to a full service on a split when it is mounted in a shop or office with minimum working space and limited time.
    Glad to hear that you're making progress.
  28. #28
    Apr 2021
    Australia
    48
    Yeah Brian_UK, hat's off to all you AC Engineers. I have far more time to play with this AC. All of you professional's will be on a time budget. And I appreciate why you would swap out old for new - time, difficulty and you need to supply a warranty...can't do that with old refurbished parts.
    Sheeez, I'm glad I won't be at this again too soon...haha, have not got it back together yet and it might knob itself when I test it...has been good learning new stuff and meeting others of knowledge though...
  29. #29
    Apr 2008
    49
    1,023
    A sterling effort so far, those Fujitsu drip trays aren't for the faint hearted!
    The difference in the model number denotes the region or voltage supply so you are all good there.
    I've stripped similar fan motors just to take a look and bearing replacement looks pretty straightforward. Like you say there will be a circuit board in the motor but the rotor will pull out easy. Not sure about the rear bearing, not taken one of those apart but guess that cover pops off somehow.
    Cheers,
    Andy.
  30. #30
    Apr 2021
    Australia
    48
    Hey thanks for the encouragement Tayters (and Brian_UK). And yes you are spot-on RE: manual mod#'s. As I had a quote for mtr replacement, at my request, just prior to me attempting. And your mod# (manuals) is also stated on the quote together with my mod#, thanks mate.
    Haha, yeah that drip tray does have a lot going on.....
    Indeed, cct brd will have some solder points to remove. Then brd can be removed (needs to, for bearing clearance) from mtr casing and the rotor will come out completely, with, front and rear bearing retained on the shaft.
    Been a bit crook, so have not split mtr. Maybe tomorrow? Will add some pics soon
  31. #31
    Struggle on dude, you'll get there.
  32. #32
    Apr 2021
    Australia
    48
    Ok my AC friends, here we go with the split. Bore hole in a some wood to act as a holder for mtr shaft, deep enough (+ diameter just > than shaft) to hold shaft but not too deep to stop cast mtr cap from moving down. I must thank a Y/tuber for this idea.
    Put some datum points (marks with screwdriver/indelible marker etc) that will allow cast metal cap to align correctly with the rest of the mtr body when re-assembling. As there is a driver chip (white mark = heat sink paste) that needs to be resting on metal cap (to dissipate heat)+ always good to re-assemble in the same orientation as originally assembled.
    Use a s/driver and gently tap (downwards) at the divot points (shown in previous pics) and cast metal cap will then come away. Hahaha, now I did this as gently as I could, however, some of the plastic making up the rest of the mtr body came (broke) away with the metal cap. This is the dark material visible inside of the cap on the circumference. I may not have been consistent in applying force around the whole cap, I think....damn you stupidity, you always follow me. Should not be an issue as it will be assembled back as per original location.
    A small dab of glue (high temp) should secure this area and hopefully shaft alignment will remain ok. I will use a high temp super glue to do this as I don't want any volatiles associated with the glue to cook off and seep past the new bearing seals.
    There is a compression washer that sits on top of the front bearing (photo).
    The cct brd has x3 solder points and some plastic welds holding it in. I will tackle these soon and document...hopefully this evening, got to hit the pool now for some laps.
  33. #33
    Apr 2021
    Australia
    48
    Alrighty then...Removal of fan mtr pcb. I used a decent soldering iron that I normally use when I populate a pcb and subsequently solder components to the board. Mine has an adjustable heat setting that I cranked up reasonably high (photo).
    We want to de solder those x3 solder points (photo showing black dots at points), as they are chunky points we need some high temps. This is needed to melt quickly and clean the solder, limits the amount of time applying heat (too much heat is destructive). I then used a pneumatic solder sucker to vac up the molten solder. Reasonably straightforward, if you have experience....potentially disastrous if you do not. The x2 plastic welds (photo black dots) can have their tops carefully broken away using flat blade jewellers s/driver. Then carefully pry up the pcb, access to remove the complete rotor is now available.
    Photos show tools used etc and rotor out, showing bearings. Bearings seem rather "dry" with some axial/slop movement. I don't have a small enough bearing puller to get them off so have to have a think what to apply to remove them. There is a c/clip behind each bearing, best to remove these before bearing removal. Also be wary, rotor is very magnetic and will find any ferrous material lying around to suck-up. Yeah, like fine little bits that will stick to rotor. Just BTW, same place where my soldering iron (photo) was made is where the bearings were also made...so, there's ya problem. I will be back with bearings off, haha, hopefully...
  34. #34
    Apr 2021
    Australia
    48
    OK, bearings have been removed.
    I'm very aware that you guys/gals will know all of what I'm doing (or have done-as it is your profession). And my documenting, is only to show others, such as me, with limited knowledge, limited appropriate tools, limited $'s but good amount of time available, a way to go about repairing (hopefully-not there yet) an AC fan mtr (+other things along the way).
    Big problem is/was I don't have mini gear/bearing pullers, I have pullers for auto use - too big. So had to improvise with what I had available.
    Front bearing I used all that is in photo#06 (+piece of wood to tap mtr shaft). Clearance/distance from rotor to bearing is limited to fit tools into. Used an old bike multitool (#1) to slide under bearing (via gap in tool). Make sure to protect rotor - hence bubble wrap. Held the longer end of the m/tool and supported smaller end on the edge of my desk. Arrow on m/tool is where shaft + bearing supported. Applied some spray on lube to shaft, gave the mtr shaft some (non forceful) hits to move the bearing further up the shaft. This allowed tool #2 (auto ball joint splitter) to then be used. The piece of inner tube rubber used to cushion shaft end - to not burr or distort it.
    Rear bearing as per photo#05. Same arrangement as front bearing, however could not fit #2 into clearance. So kept #1 under bearing supported via tool box corner (as needed more than two hands) and tapped on mtr shaft with tool #3 (brass plumbing valve extender).
    All good, bearings off, no distorting of mtr shaft ends and no damage to rotor. Keep the b/wrap under the #1 tool to stop damage when tapping.
    Keep in mind hard hits to magnetic items, IE the rotor, may disrupt their magnetic properties (heat will also affect as well), so go easy on the hits to shaft and no heating.
    If I had appropriate brass drifts would have been better. Took < 8 minutes to remove bearings. Time to cook up a scheme on how to do it took the time...if one has mini pullers etc, would be easy as.
    Just out of curiosity I weighed the old bearing(s) = 12 grms. I'll weigh the new bearing(s) and see what they come in at. Bearing specs; OD=22mm, ID=8mm, D=7mm. When I have new ones, will add more documentation. Photo#06 in following post...
  35. #35
    Apr 2021
    Australia
    48
  36. #36
    I always maintained that our assistants should come with arms containing seven elbows if they wanted to be of any use at all.
  37. #37
    Apr 2021
    Australia
    48
    Haha, that gave me a good chuckle Brian. Get a move on evolution....I've got things to juggle. OK, I have got the bearings. They are, an ubiquitous, # 608zz (Timken for me + many other brands available), easy to get and cost effective. I'm still waiting on the blower fan end bearing/bushing to rock up...a 2,700km journey from South Oz. We wait for many days/wks for goodies, I think in the UK, you get goodies in a matter of days....?
    Hopefully will have a go putting new bearings on rotor shaft tomorrow. Thinking a 10mm deep socket (as inner race od ~ 10mm) + F clamp should do the trick(?), we'll see how it goes + will include some tips to allow the "motor drive" chip (on cct brd internal to motor) to have a more effective heat-sink.
  38. #38
    May 2021
    USA,NY
    1
    Hahaha a joke with seven elbows, I appreciated, or it was not a joke ... In any case, I was reminded of this one funny story. I had an air conditioner since 2010, no one followed it. It so happened that I had to call the guys from airconservicingsingapore.com. One guy came to me, he was so pleased, called him to service the air conditioner. Everything would be fine, but my air conditioner is in a hard-to-reach place. Together with this guy, we somehow got him, but this poor fellow hit his elbow, apparently a nerve hit or something. He portrayed such a face, I suggested that he take a break and take a break, but with a smile he said it’s not worth it, although it was clear that he was in great pain. If possible, he would use foul language. Oh, he was a funny guy, of course, after the renovation, I offered him a cup of tea, and we got into conversation, as he worked the last day, that's why he came to me so happy.
  39. #39
    Apr 2021
    Australia
    48
    Apologies to all...have been busy, and have not got to the bearing install + the blower end bearing has just rocked up today. Will give it a go tomorrow and can now assemble the motor + can install the motor + blower into the d/pain and get that section completed.
    And, Brian_UK, CarolynVJ (do you bounce a lot?); don't forget, Chernobyl has not yet finished providing "gifts". So 7 elbows might be available in the near future....
    Photos of internal motor circuit board shows chip with white on it. The white is a thermal conducting paste. The chip is involved in driving the inductance magnets (coils) in the stator. So we have v.fast current switching with respect to time (di/dt), therefore lots of energy = heat. Upper chip surface will be designed as a dissipation area and the paste thermally "connects" the IC to the mtr metal cap, which will act as a heat sink and release the heat to the outside.
    However, I have noticed, that the paste on the top of this IC is now pretty much dried up (solidified). It should be a pliable paste to work effectively. This needs to be replaced. I will do this when assembling the mtr (& advise how to). Because at this point it's doing bugga all for the IC and chucking the heat back inside the mtr housing and will be the same in motors that have some age. Plus I have some (easy) info on testing these motors (+others), might be useful. I will post the link next post...
  40. #40
    5,667
    A good job takes time. Any 'coil rash' yet 🤣
  41. #41
    Apr 2021
    Australia
    48
    Yeah, mate if I'm reading you correctly (??), I have found some. I can see where the laminations that form the core of the electro-magnets, that face the rotor surface are missing a bit of their "coating". Looks as if the rotor has just scrapped the surface, but I don't see any marks on the rotor surface.
    Hey Frank, would this be consistent with bearing wear? Could it also be due to blower bearing end wear? With these two in mind, maybe a combination of both(?)...enlighten me please.
  42. #42
    Apr 2021
    Australia
    48
    OK, bearings are now installed. Photos will show what I used. Unfortunately, the 10mm deep socket was not viable. Instead I used the expansion sleeve that is used on a "hold fast" bolt. It is 10mm and I put some cable ties around the outside so it did not deform when clamp applied...that was for the front bearing.
    Rear bearing, used a washer, hole diameter just over 8mm (to distribute the load), placed a 9mm socket on top of washer, which is sitting over bearing inner race and gentle tap with hammer.
    Haha, make sure c-clips are on shaft first, applied wee bit of silicone lube on mtr shaft, then install bearings + they must sit flush with c-clip. Motor assembly next post...
    I did weight the old bearings, came in at 12grams. New bearings, also = 12grams. And I could not see any bearing lube/grease inside mtr housing, so assuming the old bearings did not de-lube.
  43. #43
    Apr 2021
    Australia
    48
    Ok chaps, here we are, re-assembling the motor. First off, I will need to rescind two bits of info I discussed in my prior posts; 1) way back I noted that the fan motor was a squirrel cage (inductance) motor...this is not the case. Because as I continued dis-assembling this mtr, I did note to be wary of the strong magnetic field of the rotor. I was then aware that due to this, we have a (permanent magnet) brushless DC mtr (it still works via inductance) as the stator (electro magnets) are DC pulsed, influencing the magnetic field of the rotor ---> squirrel cage uses AC and induces rotor and stator.
    And as with the squirrel these DC mtr's are also pretty electrically robust, can handle stall conditions reasonably well-until protection sense circuit kicks in.
    2) more recent post, I discussed that the heat-sink compound (white, on top of mtr drive IC) had dried up and was not doing the job. I started to remove this compound and noted that it was rubberised, normal h/sink compound goes flaky/crumbly. So, this may be a more specific compound to "form" around components/heat-sinks and still transfer heat. Therefore I have not removed it but I have added some more h/sink paste...this will assist in a more efficient transfer of heat to the mtr cap. Not really necessary but while I'm in there, might as well. If it dries up the original h/sink compound will still do the job.
    I used my normal vacuum cleaner with small nozzle to clean rotor and inside mtr housing (stator poles) to remove any rubbish. Then sprayed rotor with small bit of silicone and wiped around rotor with clean cloth. Because rotor to stator clearance is extremely small, don't want any crap in that gap.
    Photos added showing assembly, #01 h/sink compound used + plastic shield that fits just under mtr cap. #02 shows scuff marks on stator poles must be from rotor but no visible marls on rotor. Slop due to mtr bearings and blower end bearing probably causing this, as rotor to stator clearance very tight. #03 Rotor in without PCB. #04 PCB in and I re-did the plastic rivets, melting used cable tie to the x2 white points (black dot marks)---maybe not really necessary as x3 solder points should secure it, but easily done. #05 PCB re-soldered, socket used to make sure brd is firmly located in its position. #06 shows mtr cap and plastic shield + front bearing compression washer. #07 shield in place, it is specific in how it fits. #08 shows h/sink compound (added to IC)+ silicone paste, used (v/small drop) this to hold compression washer in place while mtr cap put on, s/glue not used at this point. #09 used a 150mm gear puller to make sure cap goes on evenly, socket (sized to just fit rear bearing protrusion) at rear of mtr to centralise puller. #10 tapped (gentle hammer) on mtr cap to secure it then used puller to pull it onto mtr housing. #11 shows what I will use to keep mtr cap attached to housing. I will secure a few points around the mtr housing circumference, clean these areas with alcohol, scuff up with emery paper and use the s/glue to (hopefully) secure mtr cap.
    NOTE: the green (paper) shim indicates that there is a slight gap present between cap and housing. I was not aware of this and cranked up the puller to remove this---yeah, not good, then realised gap was normal (I hope?). Puller is tight enough to secure cap, too tight and the bearings will bind. Can check, by spinning mtr shaft, should be smooth with no mechanical noises. I chose to glue on the outside of motor (to secure cap) so as to not introduce contaminants to the mtr internals, even though s/glue is a hi temp variety. At the moment cap is still secured by puller and I'm about to hit it with the glue---I'm thinking 4-6 spots around circumference should hold it (haha??), have to see how it goes once glued and puller removed. There are 11 photos so they will be spread over x3 posts. Next post will supply a link to a good info resource for these and other motors.
  44. #44
    Apr 2021
    Australia
    48
    Mtr-assem, continued.
    I also hope it is ok to supply this link? And a big thanks to the supplier of this info - Dennis, it seems. It discusses succinctly (because I'm a waffler) this style of motor + others used in Air Con areas. Gives the function of and wiring on connectors. If you are safe/have knowledge with AC mains supply, you could even make a tester, very easily. This will help in evaluating the status of the motor drive circuit and mtr itself. As feedback comes from the mtr and operation can be displayed via the tester (if ya make one, that is) ie: LED to indicate f/back pulses etc.
    https://www.whatwoulddennisdo.com/dc-motors.html
    Just make sure everything (different voltage sources etc) are tied to the required common ground, which is discussed in this write up.
    Anyway, Mtr-assem photos continued....
  45. #45
    Apr 2021
    Australia
    48
    Mtr-assem continued, last photo #11.
    I will now attend to securing the motor cap with the super glue adhesive discussed. And hopefully mtr can the be install onto the drain pan. Will be back to advise if successful and hopefully have it installed on the d/pan...
  46. #46
    Apr 2021
    Australia
    48
    The fan/blower mtr is now completed, s/glued mtr cap at 6 points on outside of mtr cap. Spins freely with no binding or mechanical noise, so should be a goer. Photo shows mtr with front and rear rubber mounting bushings attached + blower scroll end bearing. One with white dot = new, other = original (old one). Next step is to mount mtr + blower scroll and blower scroll end bearing into drain pan.
  47. #47
    time for a coffee... or a tinnee...
  48. #48
    Apr 2021
    Australia
    48
    Indeedy Brian_UK, spot on mate. Just back from a swim and have a coffee in hand as I type. A VB will be happening when all completed...might get to installing into the drain pan this evening...? Thanks for your support mate...always appreciated. I have also enjoyed documenting the process/progress....
  49. #49
    As a sideline you could take up technical authorship, when you have a spare minute or two of course.
  50. #50
    5,667
    I'm impressed with the motor repair.
    I would have just put in a replacement ������
