Results 1 to 1 of 1
    Apr 2021
    Cyprus
    1
    R22 compressor replacement and compatibility
    Hello i have a Matsu****a 2r10s3r126a* (R22) 115v 60hz 1PH LRA40 compressor with condesibg unit* Dometic SCMCD7K/2 (R22) 7000BTU 115v 60hz 1PH LRA40. This is Cabin Mate 207311115, 1 zone 7000 btu reverse cycle marine unit
    The compressor bottom rusted and i need to replace it. With which compatible compressor can I replace it and which gas. Can I use R410 or it will have compatibility issues with the condecing unit?
