Thread: evaporator tank milk
22-06-2006, 12:41 AM #1
hi all can you give information about evaporator tank milk i have leak in tank sorry my english thanks all milton in brazil
22-06-2006, 07:55 AM #2
Re: evaporator tank milk
if you have a leak in the tank your in trouble,it normaly fills the system with water and thats that, try draining the tank water off and break into the system to access how much water contamination there is, you may be lucky.
22-06-2006, 09:18 PM #3
Big troubles, leak in milk tanks.
Perhaps a wild idea - what's your question anyway - you can try to repair the leak.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Milk getting into glycol on chill press
By balerjoe in forum Trouble ShootingReplies: 16Last Post: 06-09-2005, 09:41 PM -
More problems with the same milk vat
By Cary in forum Trouble ShootingReplies: 1Last Post: 24-05-2004, 01:40 PM -
Removal of migrated oil in dimple plate milk vat
By Cary in forum Trouble ShootingReplies: 10Last Post: 15-05-2004, 05:36 PM -
Anyone no anything about milk cooling milk tanks, plate coolers, compressors
By neilhuxley in forum CommercialReplies: 2Last Post: 20-09-2002, 08:23 AM -
Milk Vat over controlled
By Cary in forum The Trail of TearsReplies: 3Last Post: 07-05-2002, 04:06 AM
