    Nov 2007
    Brazil
    43
    Room positive pressure
    Hi Everyone,
    Could anyone help me or recommend me some literature about room pressurization methods and how to design proper the ventilation system to achieve a positive pressure in a room?
    I know the leakage area is the main mechanical parameter in the pressurization system, but I have some doubts about the entire process.
    For instance: I have a room with a determined volume, a determined airflow by the AHU unit based in the sensible heat load inside the room.
    Some doubts comes up:
    - What the airflow to be introduced in the room to pressurize it to a determined pressure value (Pa)?
    - If the room is at negative pressure, what the common possible reasons for this?
    Thanks in advance everyone
    11,025
    Re: Room positive pressure
    Here's a starter, it is not a simple process. The designer should specify everything for the contractor.
    https://www.idealsimulations.com/blo...ressure-rooms/
    Nov 2007
    Brazil
    43
    Thanks a Lot Brian
