Thread: Pump down
    Jun 2020
    Malaysia
    44
    Pump down
    Hi guys,
    Do we have any limitation about pumping down screw or scroll compressors ? Or same as reciprocation compressors we can pump down cycles with screw or scroll compressors ?
    Thanks.
    3,356
    Re: Pump down
    Depending, but some manufacturers say short pump down on say commercial, semi industrial semi hermetic screw compressor.
    can cause overheating & failure due to overheating of windings & compressor.
    Could get oil build up to due to no flow
    Jun 2020
    Malaysia
    44
    Re: Pump down
    Thanks ranger
    Aug 2014
    75
    508
    Re: Pump down
    Never pump a scroll compressor down below 0.5 Bar or better still 1 Bar, as the pressure get close to a vacuum , the scrolls get pulled together and rotating scroll starts to run the fixed scroll . As the pressure goes lower the scrolls are sucked into each other as it pulls a vacuum causing metallic particles to break from the scrolls leading to over heating and scroll breakages
